Balancer question
  • Drake Racing
    • Dec 2007
    • 138
    Balancer question
    IMCA late model engine, no balancer, only the 3 ears that the pulley bolts to, no ring.
    Has anyone done this? I know sprint car guys used to, but never seen it on late model
    engine. Curious if engine would start cracking internals from the vibration.
    Curt Drake
    #55x
  • Ferg58
    • 519
    Dont run it without it. I had a motor that had that done before I purchased it. Broke snout off of the crank later on. I know that was the reason. They had timing chain issues before that too. Put one on it.
    • let-r-eat
      • 2319
      Do not run without one unless you want to work on the engine after every night.
      BUCKLE UP NOW, YA HEAR?
      • Rodz
        • 34
        When I have an engine come in for a freshen up without one, It doesn't leave without one. Crack check everything. It can cause problems everywhere even valve train issues and there's nothing to be gained with a hub. HP can actually increase with a balancer.
        www.avengerraceengines.com
        • dave41
          • 208
          balancer
          had ring come off latemodel , lost torque, would not pull up straights.
          • racin6mod
            • 2172
            A engine builder in the area builds all of his motors with the crank hub. they have trouble keeping the carb bolts tight and the bell housing bolts. it's a bad idea I told him if it were possible to run a race engine with out a vibration dampener the cup guys would be doing it(they use a bigger balancer) most of the cup motors are balanced to the highest level and run short strokes, sprint cars use the water as a vibration dampener. the water pump is run off the crank snout.
