Is there a rocker arm out there that will clear a 1.580 in' spring without cutting or gringing???
I have Dart Iron Eagle Platnium heads that were cut to accept the bigger springs, +.200 on the valves, and ARP 7/16 studs. I have tried the Scorpion Race Series brand that was advertised to clear 1.625 but they needed a lot of cutting/grinding...called Scorpion in FL just to find out the advertised clearance is for stock stuff. Now, I had the Comp Cam Ultra Golds overnighted and they are supposed to clear 1.650...that didn't work either. The Ultra Golds seem to fit when they are seated on the stud but that was after removing the pushrod and stud, then insert the stud in the rocker arm and wrench it onto the head. It just doesn't fit on with the stud already in place. Don't have the time or budget to switch to a shaft system right now, just looking if this has happened with anyone else.
