Burning Roller Tip Rockers
  • dereksehi
    • Jun 2013
    • 307
    Having a problem burning comp magnum roller tip rockers spring pressure is 130 on the seat and 340 open does anybody have any tricks to keeping these alive?
  • 35smod
    • 286
    More oil take the restrictors out if you have them in check to make sure they're oiling good while the engine is running
    • dereksehi
      • Jun 2013
      • 307
      I have had it idling with the valve covers off and there is enough oil to completely fill each rocker
      • Lizardracing
        • Sep 2009
        • 839
        What the weight of the oil and whats the Oil temp?
        • dereksehi
          • Jun 2013
          • 307
          It's 20w50 valvoline vr1 synthetic I don't have an oil temp gauge so not sure on temp
          • speedbuggy
            • 259
            Either install a stud girdle or oil deflector (Speedway Item # 54567700) to get more oil on your balls.
            • stock car driver
              • 3233
              do you have restrictors? you cant run them with ball type rockers
              • 48bad
                • 30
                Do you have solid or hydraulic lifters?
                • dereksehi
                  • Jun 2013
                  • 307
                  Solid and its restricted with a single .150 restrictor
                  • dereksehi
                    • Jun 2013
                    • 307
                    Just thought I would let you guys know we got the issue fixed we welded deflector tabs on the rockers above the oil holes.
                    • stock car driver
                      • 3233
                      restrictors are for full roller rockers since they don't need as much oil to cool
                      • Lizardracing
                        • Sep 2009
                        • 839
                        They're never "needed" if the block is prepped correctly regardless of lifter or rocker configuration.
                        • Krooser
                          • Nov 2012
                          • 3117
                          Some guys have fixed this issue by using un-grooved rocker arm balls...
                          Class of 2019
                          • dereksehi
                            • Jun 2013
                            • 307
                            We installed them along with welding on the tabs
                            • stock car driver
                              • 3233
                              un grooved were worse when I had to run this type
