Head/engine question
  • dirtracertodd
    • 18
    Would a set of WP I037 heads work with a 377 engine combination for a dirt modified with the right cam choice? Please explain pros and cons, as I am not an engine guy by any means. Or am I better off with a 355? I was planning on buying a Dart SHP block because I have a light weight 3.5 stroke crank and 6 inch rods already. I was looking at the 377 to help kill some of the torque on tracks that go dry slick in the summer.
  • dirtracertodd
    • 18
    Wow.. Over 100 views but no comments on my question..
    • powerslide
      • 2696
      head won't make enough power to need to kill torque. Build the 377. SHP block with a good crank and rods should last you awhile
      • dirtracertodd
        • 18
        Not enough power out of the heads? What can I expect before I spend a lot of cash in the heads?
        • let-r-eat
          • 2319
          I037's aren't a bad head in the right hands.
          BUCKLE UP NOW, YA HEAR?
