Ignition ?
  • RacerX10
    • 571
    Ignition ?
    Need to know what sort of ignition setup sprint cars are running these days. I'm a late model guy so everybody here is running some variant of the MSD 6 setup.
    I'd appreciate any comments .. esp with part numbers of equipment that you guys are running.
    Thanks !
  • Stede Bonnet
    • Sep 2016
    • 325
    Magnetos for the most part, but there are some newer crate based wing and non-wing groups using either the factory HEI's on GM602/604 or coil pack setup on the CT525. The most popular group on the economy end of things is "Racesaver 305" and they typically all run magnetos since anything else requires a battery at minimum to function. Hope this helps, I myself am working towards moving away from late model and starting up a group of Non-wing sprints in the Southeast, probably including the racesaver 305's, GM602's, GM604's, MOPAR and Ford crates too, and possibly some stock block/head engines, like an LS 5.3. Not sure about CT525 yet as its much more expensive, lighter and more powerful, so... Trying to be inclusive instead of exclusive though.
    Politically Incorrect.
    • RacerX10
      • 571
      Thanks Stede
      • Renegade Cust Susp
        • 349
        Thanks !
        Vertex or Mallory magneto
        Msd ProMag are about all you will find guys running
        Broc Burton
        go.fast.crs@gmail.com
        • Stede Bonnet
          • Sep 2016
          • 325
          Joe Hunt is another brand used, they even sponsor the wingless spec sprints in California.
