Results 1 to 12 of 12
    Aug 2011
    544
    Default Wheel offset affect?
    Im looking for a easy change for when the track slicks off after the heats. In the rr I run a 3" offset wheel. What will a 4" do to the car? Im trying to avoid making too many changes while i learn to drive. Also the same question for stagger in the rr?
    Aug 2011
    544
    From my understanding less offset in rr will loosen car as well as more stagger, correct? Are these good changes to make for what I'm trying to do?
    Jun 2009
    Central IL
    654
    RR more to the outside = less weight on rr, which effectively gives you more cross. also softens RR spring rate, by moving contact point further from spring mounting point. when we ran rr spaced out it freed it in and middle, but can also tighten exit. so going with less offset (opposite effects) should tighten in/through, but can loosen exit. We had better luck with running lr spacer in slick (or more LR offset)
    Mar 2011
    197
    Quote Originally Posted by jsf74 View Post
    IMHO
    run 3 to 3.5" of stagger all the time.....
    buy a couple of 1" spacers..... put one on the RR for heat.... after heat... pull it off RR and put it on LR.... take the other one and put it on the RF....
    Aug 2011
    214
    i have a spacers on the lf and rr so if i would switch them around it would tighten the car up for the feature instead of moving bars or adding bite. Track does not change alot between heat to feature for us.
  6. #6
    Jun 2009
    Central IL
    654
    Quote Originally Posted by johnny v View Post
    IMHO
    I'd agree with that too
  7. #7
    Jan 2012
    Bakersfield, Ca.
    51
    I was always told your not suppised to use spacers on the front.
  8. #8
    Aug 2011
    544
    Can u explain why other than leverage on the hub?
  9. #9
    Mar 2011
    197
    Quote Originally Posted by imca90 View Post
    ok, pull the 3 " offset off and replace the wheel with a 2"..... What's the difference?
    Maybe before everyone went to the 5/8 lug bolts....... that might have been true.....for wheel load and such......
  10. #10
    Jan 2012
    Bakersfield, Ca.
    51
    I dont know i never understood it either.
  11. #11
    Jun 2009
    Central IL
    654
    changing offset changes the amount of suspension travel. so you either get more or less dynamic change in geometry based on the increase/decrease. I believe it's less offset (wheel in closer) is more change/travel, more offset (wheel out more) is less travel. Not necessarily a bad thing, just have to keep it in mind.
  12. #12
    Mar 2009
    Dogwood Illinois
    701
    When changing rear offset dont forget to adjust stagger slightly also. A thing called stagger ratio.
