Originally posted by MI Dirt Fan
View Post
Left-Rear Weight
225$ for a lr axle that can drastically change your cars drive and turn is cheapOriginally posted by ReignMan23 View PostDalemcfan, I didn't even know there was a tech section, I will have to cross-post and see what I get there, thanks for the info. Thank you Ryan, TB, and Centeroff, good info! I have been researching and found a company called Strange Oval, they sell heavier and lighter axels, i'm guessing heavy for tacky tracks, and the lighter axels for when the track slicks off. Are guys really going to be switching axels pending if it's dry or tacky? Seems expensive if this is what guys are doing.
Really the only part left untouched is the axle tube and there is only so much you can do with the restricted diameters and materials. Some builders have used steel tubes on the left for years. The available "heavy" tubes are only a few dollars more than a standard tube. Check with ALL of your manufacturers to confirm that. If they are selling for more than that you can bet the the material is wrong (only aluminum and magnetic steel allowed). If that becomes an issue series will simply swapping tubes out.
The birdcage is pretty well covered with the same general design on both sides. Meaning you can have a big thick bird cage but you have to have them on both sides. And remember that just because there are no maximum weights listed for a birdcage doesn't mean they can't be removed and weighed to help with an index of suspicion on material.
In regards to weight on the axle tubes - yes there is a method that would be plausibly safe. However for every one that used that method 10 more wouldn't. Anything that is dynamic shouldn't have ballast mounted to it. We have a problem in this sport with guys mounting seats and belts properly. Or guys using out of date belts and safety equipment, which is as much the series' fault as the drivers - however you see the point.
All your dynamics must be referenced to ground. Is the chassis not very dynamic?Originally posted by flagone View PostReally the only part left untouched is the axle tube and there is only so much you can do with the restricted diameters and materials. Some builders have used steel tubes on the left for years. The available "heavy" tubes are only a few dollars more than a standard tube. Check with ALL of your manufacturers to confirm that. If they are selling for more than that you can bet the the material is wrong (only aluminum and magnetic steel allowed). If that becomes an issue series will simply swapping tubes out.
What is wrong with two heavy cages?
And why is buying a thick tube cost saving over shoving a sleeve in the one I have?Last edited by MasterSbilt_Racer; 02-02-2017, 06:07 PM.Modern Day Spec Wedge Racing
They have essentially took a safe, cheap bolt on part and made the extra weight cost the racer a bunch. If the weight bolts where high enough grade and large enough it was a cheap safe deal. Now it's not cheap, just like most rules.
The thing is, the shocks got so good in dampening and tune ability they no longer fear unsprung weight.. There is a very large thread on this in the Dirt late model section.
The chassis is significantly stronger and less likely to break than an axle tube, radius rod or birdcage under dynamic motion or in an impact.
You can do 2 heavy cages but I don't think you will see anyone doing that.
Sleeves are no cheaper than buying an axle tube.
25# lead bolted to a 1.25 or 1.5 .065 DOM or Moly tube with a small weight clamp on the chassis is stronger then clamping the same 25# a 3.0 x .25 wall aluminum tube or 3.0 x .125 wall steel tube? Wow, didn't know that.Originally posted by flagone View PostThe chassis is significantly stronger and less likely to break than an axle tube, radius rod or birdcage under dynamic motion or in an impact.
And where does it say they have to weight the same left vs right on cages? Wording is so bad, it says as similar as possible nothing about weight at all. Lots of room for interpretation there.Last edited by billetbirdcage; 02-02-2017, 08:10 PM.
The only way, OTHER than using illegal materials, to make a birdcage heavier would be to add material - making it bulkier or larger overall.
How often to frames break compared to the other parts?
My last post on the subject. The rules are in place. Everyone has a better idea - everyone. But these are what we have.
I will send you a picture once I get my cages done.Originally posted by flagone View PostThe chassis is significantly stronger and less likely to break than an axle tube, radius rod or birdcage under dynamic motion or in an impact.
Sleeves are no cheaper than buying an axle tube.Modern Day Spec Wedge Racing
Why did they go away from the plan on weighing the whole rear assembly hanging in the car. It's fair, fast and easy to tech. I just do get that part at all. Then you guys backtracked on the cage weights again don't understand that besides it's a nightmare to tech.Originally posted by flagone View Post
I'm not trying to make you mad or clown you, just don't understand why they decided to go the route they did. Either stop it all or none of it.
Granted you guys did take care of the most dangerous part of some of what was going on with the rules (many don't know about this so I'm not going there but you should know what I talking about), but seem to gave in to others and make getting the weight there more expensive in many ways.
I think we have reached the point that Lucas and Woo should just go their way and fight their battles and leave the grassroots racers alone. They can fill their series or not.Originally posted by flagone View PostIt is a group decision. I am only one vote and voice. But at the end of the day everyone having the same rules is cheaper no matter what.
MasterSbilt please do. My phone number and email are both posted.Modern Day Spec Wedge Racing
