Bobby Pierce on twitter - HELP Cost Limit engine size to 415 - 420. Link.
    Bobby Pierce on Twitter - An idea to cut some cost - Limit engine size to 415 - 420
    Link - http://www.twitter.com/BobbyPierce32...07571928133637
  • plunks7
    • 3274
    To Bad and no freaking way!!!!
    • Highside Hustler25
      • 12972
      Bobby P. Not Billy M
      8/13/16
        And give them a weight break as well. That rule worked pretty good in the Havatampa days!
        • 93Nelson
          • Jan 2014
          • 178
          Bring in the crates!
          Just a Sportmod racer at Nelson Boys Racing.
          • Burke1118
            • Mar 2018
            • 222
            Not sure what this will accomplish. NASCAR engines are 358 cubic inches and have just as much power as our stuff.. only difference is Nascar engines are way MORE expensive
            • Cardirt0
              • 5271
              Spend more get more.. but then you brake more. Then it cost more to fix. NASCAR 3 races they toss the block. 4 races the heads get sold.. I bet after next year they go to Speck frames and Speck Bodys
              • BILL47A
                • 80
                If this were to become a rule, I would guess the cubic inch displacement of the engines in all the cars would have to be checked prior to the event. I don't know the process they would use to do this and how time consuming would it be?
                • Dlmfan123
                  • 4520
                  Dudes just throwing out ideas. It’s ridiculous what these guys spend and there’s really no way to stop them from spending more
                  • Cardirt0
                    • 5271
                    At lease Bobbys saying something. may be if all the drivers and owners stand up and sit down and speak to each other may be something can be done.
                    • Mod Runner
                      • Jan 2012
                      • 723
                      No way do I want to see an engine cubic inch limit. They are called Super Late Models for a reason. No Neutered Late Models for me !
                      • TackyTracker
                        • 5316
                        think about them not running anymore?? costs have to go down or lucas & woo will split the main jewels and have a series but that will be it if something doesn't change..
                        • chupp n bloomer fan
                          • 11526
                          Not a bad idea. But you’d have to really look at everything and every loophole the guys would try to use. He’s on to something and you wouldn’t know the difference, fields aren’t going to grow. They are going to continue to shrink with the current situation.
                            I don't like this. A bigger crank costs the same as a smaller one. Engines get cheaper when you can't use a big one. This concept is a relic from the days where everyone had a set of 23 degree heads.
                            And less cubes means more rpm and more top end failures. Bobby wants lms to still "look cool" aka be glued to the ground and get cheaper. It don't work like that.
                            • kazual
                              • Jul 2014
                              • 1168
                              People will generally promote a rule where they feel they have an edge or an advantage. Be that engine, tires, etc. Happens in almost every part of life including business and sport. Not saying this is Pierce’s angle here, honestly I don’t know enough to take a side. But usually when a participant is on board with a rule modification bet your bottom dollar it isn’t something that they see hampering them individually.
                              I hate time trials.
