Rear suspension history question
  • Austin34471
    • May 2010
    • 174
    Originally posted by hardracer32 View Post
    MasterSbilt_Racer I wondered if anyone would bring up the ol' clamped birdcage set up. I remember the first time I saw a car run with that and they carried the left front all the way down the back straight. That was being run for quite a while before the shock behind set up took off. I kinda wish neither of those set ups had ever been allowed. I think the evolution of DLM's would have been much different had we not let that Pandora's Box open.
    The spring behind just showed that everyone was running way to stiff of a LR spring back then. Nothing magical about the spring being physically behind the axle tube. If skip arp woulda said “ay joe let’s put a 50lb spring in the LR and try it” he would have had a similar result.
      Originally posted by HRT2332 View Post
      The problem is that Skip and Joe didn't tell where they received their info from. I was helping an a helmet painter when certain people saw the rear design of the car that we were building in his garage. Those people ask him what he!! he was thinking and trying to do as they looked at him like he was stupid. He told them and there u have the shock and spring behind. We were also doing the double RR shock and spring during the build at the same time. By the time we finished building the chassis the rear suspension had already taken off. We will just leave it at that.
      Not to argue with you, but that's not Skips version!
      • fastford
        • 4059
        austin , the spring behind utilized the indexing of the bird cage to help keep spring loaded , but your right about to stiff of a spring but a stiff spring utilized this action more , today with the stacked or long soft spring , i dont think the indexing is as important....jmo.....
          There is more than one way to get a soft wheel rate. Pluses and minuses no matter how you do it.
          • anissa5
            • Jul 2010
            • 79
            Birdcage clamped
            Was the birdcage clamped or just shock and spring
              If you clamp the birdcage, you must remove a bar and have a 3 link. Or, you will break stuff.
              • dirty-white-boy
                • 997
                I thought Hot Karl Chassis came up with the idea?
                • fastford
                  • 4059
                  we never ran it on anything but a 4 link , but your right , it is abusive on parts if there is any bind up , and with todays left rear suspension movement , i dont think it would work......
                    I assume you mean clamp the coilover mount? Not the cage, correct? I mean you could, but it is taking wrap-up torque. Everything would need to be strong enough... And you would not need a lift bar or pullbar.
                      In 96 when GRT/Frye started developing that for their cars, they kept the top bars on. They/us never had a problem with breaking parts!
                      FWIW......With this setup, Frye came from the rear to win the Shootout, passing Bloomer on the outside! The best and only good race I have ever seen at Dixie!
                        I'm shocked that was ever effective. I have floated leaf springs instead of clamping them to the tube!
                          I could envision some interesting things with a mono on the lr!
                          • fastford
                            • 4059
                            yes , the bird cage we used had the option to leave shock mount bolted to bird cage or take bolt out and bolt it to the inside clamp which put it clamped to the axle tube , we ran a lift bar , with a weaker spring , but that was about it other than a stiffer rebound on 5th shock....it made very good forward bite in the slick...
                              Were those the twm's, like the ones grt used?
                                Ok. I'm with you now. I ran that sometimes on a Mastersbilt.
