Rear suspension history question
  • EvelB7
    • Jan 2018
    • 909
    #31
    Initially the coil-over was in front mounted to birdcage, it all floated. Mid to late 90's they split the birdcage so you could either bolt the two halves together (making it one piece) or 'clamp' the shock to the axle tube (the half with the coil-over mount would have a bolt that made it solid with the axle). Gave a very good amount of lr drive, the issue was really when coming off the gas it would tend to 'slam down' if you could not ease out of the gas. When the coil-over moved behind the axle we would still 'clamp' the front shock at times, worked very well.
    • fastford
      • 4059
      #32
      Were those the twm's, like the ones grt used?
      yes they were , i still have them some where..
      • fastford
        • 4059
        #33
        it would unload quick , we tried to counter this by more angle in upper bar and very aggressive brake pads on left rear , with the proper amount of trail braking , you could still get in corner pretty good.....
          Our buddy, Frye, had the lockup mount, but he didn't have an extra bolt. Do you know how hard it is to find an extra long bolt, when you have the whole lr tore apart, in between the heat and b-main? lol
          • Virginia dirt slinger
            • Nov 2019
            • 5
            #35
            This has been a great read! I'm currently building a vintage leaf spring late model. I can do anything I want with the suspension as long as I'm using the leaf springs. I've been thinking of going with the mono leaf/coil over/ with a lift bar. What's some other things done back in the day as far as floating the left or right side? Front spring rates and stuff?
            • RapidRuss
              • Jun 2017
              • 84
              #36
              If you see Bloomquist at a track somewhere when he's not busy ask him some stuff. I know Scott and Duwayne Hommel ran 1 much later than most testing new leads and stuff. Scott thought for awhile that leafs might still be faster on certain tracks. He now knows the 4 bar drive off is just far superior.
              • Hoosier_Dirt
                • Mar 2012
                • 1632
                #37
                I was under the impression that Larry Phillips tried it first in the mid 90's with no success, and that's where Joe Garrison got the idea from? Maybe I'm wrong.
                • Taboo62
                  • Nov 2019
                  • 42
                  #38
                  Originally posted by No_Weak_Links View Post
                  If I remember correctly Bloomquist even tried to reinvent the leaf spring in some form with no success.
                  Not exactly. Bloomquist was involved with some testing with Hyperco/Warrior when they introduced their composite leaf springs. The chassis I believe was actually built by Warrior and Hommel did some of the driving duties during testing. I have some pics somewhere of it, but "No" Bloomquist didn't try to reinvent leaf springs. By the way, the springs work great, I helped a guy win the Victorian Super Sedan Championship with a set of those leafs in 2015.
                  • dirty-white-boy
                    • 997
                    #39
                    This is the man that did most of the suspension innovations over the past few decades
                    • dirty bert
                      • Mar 2015
                      • 297
                      #40
                      Hommel came Baxter TN one night with one of Scott's own car's,it was a big race for the supers and he kicked butt talking to him after the race and he said he was helping Scott try some new leaf spring.This was after most people had quit the leafs.
