I need tie rod lengths for a 05 grt. GRT says 16 1/2 left side. I assume the rack should be centered. I don't see how 16 1/2 will work.
setting tie rod length?
Ideally the rack should be set so when straight ahead both tie rod ends on the rack are the same distance outside the lower control arm mounting points (usually around a 1/4 to 1/2" outside on both sides). If this doesn't allow you to turn far enough right then the rack plate is not located left to right like it should be which is a common problem it seems, lol.Originally posted by ace1 View PostI need tie rod lengths for a 05 grt. GRT says 16 1/2 left side. I assume the rack should be centered. I don't see how 16 1/2 will work.
With rack centered a 16.5 turns the LF way out. Looks like I would loose steering to right after turning to get it to go straight. Looks like it should be the other way around and pull the LF in and have to turn it back left to get straight and give more steering to rt. Am I looking at it wrong? The ends of rack are just outside the control arm mounting points.
billitt could be right also,, there where different cross member for a 05 it may have been changed and not done right, I would center the steering wheel, give a little extra to left and see where your at, lower control arm lengths mean a lot also. my 05 had a single round crossmember
if the rack plate isn't twisted then its the way it was built, I ran the gray spindles on mine, thought the r lower was 18 5/8 and mine used the 19" rack. also used the holes closes to cross member to mount rack. just wandering whats the chassis number .
Its under rail. On the rack being lower on rt side looks like it would effect bump steer pretty bad. I don't know much about bump steer but looks like it would toe the rf in a lot. Every thing is original to the car. I may have to do some shimming. Thanks
