setting tie rod length?
  • ace1
    • Oct 2007
    • 205
    I need tie rod lengths for a 05 grt. GRT says 16 1/2 left side. I assume the rack should be centered. I don't see how 16 1/2 will work.
  • rakracing
    • Dec 2014
    • 218
    16.5 sounds right, bolt it on and make the rf, remember jack Sullivan telling me this at grt, wanted most of the turning to the right, said make it turn to right till 1" from hitting the header or frame
      • 2019
      Ideally the rack should be set so when straight ahead both tie rod ends on the rack are the same distance outside the lower control arm mounting points (usually around a 1/4 to 1/2" outside on both sides). If this doesn't allow you to turn far enough right then the rack plate is not located left to right like it should be which is a common problem it seems, lol.
      • ace1
        • Oct 2007
        • 205
        With rack centered a 16.5 turns the LF way out. Looks like I would loose steering to right after turning to get it to go straight. Looks like it should be the other way around and pull the LF in and have to turn it back left to get straight and give more steering to rt. Am I looking at it wrong? The ends of rack are just outside the control arm mounting points.
        • rakracing
          • Dec 2014
          • 218
          billitt could be right also,, there where different cross member for a 05 it may have been changed and not done right, I would center the steering wheel, give a little extra to left and see where your at, lower control arm lengths mean a lot also. my 05 had a single round crossmember
          • ace1
            • Oct 2007
            • 205
            the cross member is 2 square tube pcs. the rack plate has 2 sets of outer holes and a middle slotted hole. Everything looks original. This chassis is extra clean and straight for 05. Left lower is 16 5/8, rt is 17 5/8
            • rakracing
              • Dec 2014
              • 218
              ace, that all sounds right is this a square tube chassis , all mine where 2" round overrail cars, still think the 16.5 will work
              • ace1
                • Oct 2007
                • 205
                Its round tube. I'm checking for a bent spindle. I'm missing something.
                • GRT62
                  • Jan 2014
                  • 177
                  I see that you are running the narrow right front. You don't by chance have the wide rack in it do you?
                  • ace1
                    • Oct 2007
                    • 205
                    It's 18 1/4. I don't see how the wrong rack or a bent spindle could turn the lf out this far. I'm going to swap spindles and see. I have a picture but can't figure out how to put it on here.
                    • ace1
                      • Oct 2007
                      • 205
                      It was the spindle. My eyes aren't what they used to be. Thanks for the help and suggestions.
                      Now another question. The end of the rack on left is even with lower control arm mount point. The right is below mount point. Is this right.
                      • rakracing
                        • Dec 2014
                        • 218
                        if the rack plate isn't twisted then its the way it was built, I ran the gray spindles on mine, thought the r lower was 18 5/8 and mine used the 19" rack. also used the holes closes to cross member to mount rack. just wandering whats the chassis number .
                        • ace1
                          • Oct 2007
                          • 205
                          #2549 which makes it a 04. I'm just trying to get everything lined up right so I can get new rod lengths and heims on it.
                          • rakracing
                            • Dec 2014
                            • 218
                            I had #2591 should be the same style, best car I ever had, won a lot of races with it, it loved big money races, any questions you can pm me, is this a underrail or over
                            • ace1
                              • Oct 2007
                              • 205
                              Its under rail. On the rack being lower on rt side looks like it would effect bump steer pretty bad. I don't know much about bump steer but looks like it would toe the rf in a lot. Every thing is original to the car. I may have to do some shimming. Thanks
