Crate motors
  • hipower17
    • 643
    Crate motors
    if you bust a block 604 or 602 is there a gm block that is a legal replacement or can a bare 604 an 602 block be bought from gm?
  • brad hibbard
    • Oct 2007
    • 974
    both engines use the same block and both engines came from the production line so to answer the first part of your question ---YES you could possibly find a block from another application that will be legal
    the problem is usually they are wore out and crate engines have no provision for an overbore.
    second part of your question is also ---YES
    here is a link to a new block from GM ---they are finished and ready to assemble after a quick wash---and they come with cam bearings
    don't be confused by the description noting 4.00 to 4.030
    they are 4 inch and can be bored to 4.030 for other applications
    Brad
    • dirty white boy
      • 1238
      brad what production blocks can be used? any one piece rear seal block??? our track owner encouraging teams to build up there own 602s and local engine builder check them n seal them! seems that would cost more in parts than buying a new one from gm
      white trash motorsports
      • brad hibbard
        • Oct 2007
        • 974
        the 602 block was commonly used in pick up truck applications (late 80's thru the 90's) is what I have been told by dealership parts people
        look for casting # 10243880 on the back passenger side of the block (below distributor)
        basically the entire engine is a production engine with the exception of the intake, oil pan, valve covers
        I am not sure about the camshaft but it may also be the same in some applications
        Brad
        • dirty white boy
          • 1238
          thanks brad!
          • hipower17
            • 643
            do these only come with 4 bolt main caps?
            • MLR19
              • 475
              The crate motors are 4 bolt main caps, the 880 block from a production car could be either 4 or 2. GM makes a replacement block & also a replacement short block for the 604 (search ZZ4 Short block) I think the complete short block is available in the $2200 range.
              Short Block Part # 12561723
              • a25rjr
                • 3774
                Heres one from pace performance at $2149,free shipping, and $250 rebate.
                http://paceperformance.com/i-6255345...ck-engine.html
                Turn LEFT, Vote RIGHT!
                • dirty white boy
                  • 1238
                  why wouldn't this zz4 work for a 602?
                  • MLR19
                    • 475
                    I believe the 602 uses a different piston
                    • brad hibbard
                      • Oct 2007
                      • 974
                      The 602 has a different crank and different pistons
                      GM just dropped the price of the 604 short block and it has changed our thought process going into rebuild season
                      any time an engine needs pistons it just makes sense financially to use a complete short block
                      MLR19---thank you for the heads up on the casting number possibility of being either a 2 or 4 bolt main block
                      I did not realize that
                      Brad
                      • hipower17
                        • 643
                        what are the difference between the newer alum. head and the older, and are there any hp to be gained with the newer head?
                        • brad hibbard
                          • Oct 2007
                          • 974
                          Depends on what you call the "newer head"
                          the 604 aluminum head has always been casted and finished with the same specifications and dimensions
                          with the exception of the spring package there has never been anything intentionally changed
                          many people talk about the logo change on the end of the head----it was exactly that---a logo change
                          nothing else was changed
                          if you go back before 2009 the valve job was not real good but that is fixable
                          the heads certainly look nicer these days but we do not see any gains
                          the bee hive valve springs are certainly a plus but other than that they are all pretty close
                          Brad
                          • hipower17
                            • 643
                            thank you again brad for the info
                            • brett4
                              • Sep 2010
                              • 88
                              Brad,after how many races do you suggest new pistons???
