Left Frt. Upper Control Arm Mounting
  • ace1
    • Oct 2007
    • 205
    I need a left upper control arm for a 08 Mastersbilt. Calls for a 10 1/4". It mounts to the inside of the frame. If I can't find a 10 1/4, would there be any issues using a shorter and mount on the outside of frame?
    • 2020
    It will work but your camber curve will change and you'll lose more camber when the LF of the car lifts and it will change your bumpsteer.
    *Not a masters guy but assume mounts will allow one to be mounted outside of the frame*
    • ace1
      • Oct 2007
      • 205
      I think I'll keep it on what it calls for. Thanks
