Oiled vs non oiled
  • Jking24
    • Oct 2017
    • 1519
    Oiled vs non oiled
    Specifically speaking walker oiled filters vs non oiled pros and cons. Im looking for feed back from real world experience. I would hope brad hibbard can give some good info
  • EvelB7
    • Jan 2018
    • 909
    Oiled are able to be cleaned and do collect dirt better, however horsepower wise hard to beat a good old paper filter. Biggest thing with the Walker is do not 'over oil' them, and you will know when you do. Key with both is proper care; for the paper that means replacing very often (sometimes twice a night in the south)...Do know a few guys who qualify with paper and switch for racing, especially at big dollar crate shows. Probably just as important as the filter is to get the correct base/top for your application...
    • Jking24
      • Oct 2017
      • 1519
      thankyou but im not asking about a traditional paper filter. Im asking about walkers newer dry washable filters vs traditional oiled
      • EvelB7
        • Jan 2018
        • 909
        I know a few who are running the non-oiled (had one brought to the dyno that car was down on power- filter just needed cleaning). The replacement time is shorter for the non-oiled so it will cost a little more to run over the long run. Less mess but at least with the oiled version you can control how much (and how fast it 'fills up) based on where you are racing. Limited late model type engine in the south, I will stay with the oiled for now. Less dusty area of the country the dry filter probably would be great.
        • Jking24
          • Oct 2017
          • 1519
          So i ran the walker non oiled for about 6 weeks this season and found it to work well on wet to moderately wet surfaces but in the dry slick it would let finer dust through. Possibly to fine to be of concern but i pay all my bills and i did not like it so i switched back to oiled. Dyno numbers don't much matter to me in this department unless it's a huge number. I'll sacrifice 5-10 hp if it means the engine living night in night out
          • EvelB7
            • Jan 2018
            • 909
            Have been running a walker oiled ( oiled once every 4 races, clean with water in between races but only oiled every 4th) on a ct525, had an issue with lifters so it came apart- year and a half on it and everything looked like new (rings, bearings, cylinder walls). Biggest thing is just not to over oil...
            • Jking24
              • Oct 2017
              • 1519
              I clean and oil mine every week. Alot of weeks we will run 2 nights in a row. on those weeks it gets run 2 nights and we don't touch it until returning to the shop. I've never tried rinsing it but not full on cleaning it. I agree with over oiling. I'm a fan of k&n spray oil for 2 reasons the first being i don't always have time to let the filter sit for a day or 2 while the oil wicks in and the second is i feel like it's the quickest way to get a uniform lite coat of oil.
              • EvelB7
                • Jan 2018
                • 909
                I completely agree with the k&n spray, way easier to control the amount and distribution.
