Carb for 604
  • jgebhardt
    • Jun 2012
    • 82
    Carb for 604
    What is a good size carb for a 604. Also curious about E-85 vs pump gas or race fuel. I talked to several guys at Dixie speedway that say they are just running pump gas and I know a few others that are running E-85.
  • brad hibbard
    • Oct 2007
    • 974
    this is a very common question on here and you are going to see alot of good names pop up and most of them are very reputable and good builders------keep in mind crate carbs are their own breed with special calibration---- make sure you choose a builder with crate carb expierience.
    we use exclusively Stealth carburetors here @ Race-1
    and we recommend the new 700cfm carb for best all around use
    you can see them on our website @ www.race-1.com
    Brad
    • roundtrack
      • 90
      Brad helped us with our purchase of Stealth 700 cfm carb. We bolted the carb on out of the box and it has performed flawlessly without a single adjustment. Our 604 has KSE rear pump, KSE fuel pressue regulator on Ratman fuel. It is also 6 lbs lighter than Holley/Willy's Crate carb. I would not have believed it, but weighed them side by side. I would recommend this carb and you cannot go wrong with purchase made from Race-1. Brad has listened and responded to every technical question we have had.
      • 50j
        • 1047
        I use a lightweight all aluminum JDR E-85 carb on a 604 and it's been flawless. It made more power than oxygenated gas and the fuel is cheap.
        • Egoracing
          • 4852
          Some series and tracks are not allowing E85 so make sure that all tracks or series that you may run allow it before buying the carb for it.
          • steelkiwi75
            • 366
            im right with 50j. i also have a jdr e85 carb and it works great. Also john is always happy to answer any questions you may have. good guy. 75f dennis feheley
