602 fuel pump
  • sikjeep
    • Mar 2009
    • 15
    602 fuel pump
    Would a new stock pump be enough. I have one from my bomber motor, or should i upgrade? What pump would u recommend on a budget?
  • Matt49
    • 3123
    We've used this one on crates with good results.
    • pcope98
      • Jan 2009
      • 225
      that carter pump is nice and that is what im currenttly running but i also used this pump from spedway motors Price: $69.99
      S/B Chevy 110 GPH Fuel Pump (Gasoline)
      Item #:
      5791002
      side note the fittings you should need will run you about10-15 bucks for both of them for for about 85 dollars you could get something that will be perfect for a 602 im running this on a 604 with no problems at all
      • dirty white boy
        • 1238
        do ya need to run a regulator with these pumps??
        white trash motorsports
        • pcope98
          • Jan 2009
          • 225
          no regulator for either one,when i first started running crate i was using a race pumps setup with a regulator got tired of the constant regulator and fuel pump issues ive have run the cheaper pump i listed 50 plus nites no signs of problems, im also running there other carter thats listed on my other 604 with no problems either...
