Would a new stock pump be enough. I have one from my bomber motor, or should i upgrade? What pump would u recommend on a budget?
602 fuel pump
We've used this one on crates with good results.
that carter pump is nice and that is what im currenttly running but i also used this pump from spedway motors Price: $69.99
S/B Chevy 110 GPH Fuel Pump (Gasoline)
Item #:
5791002
side note the fittings you should need will run you about10-15 bucks for both of them for for about 85 dollars you could get something that will be perfect for a 602 im running this on a 604 with no problems at allLast edited by pcope98; 11-04-2010, 11:18 AM.
no regulator for either one,when i first started running crate i was using a race pumps setup with a regulator got tired of the constant regulator and fuel pump issues ive have run the cheaper pump i listed 50 plus nites no signs of problems, im also running there other carter thats listed on my other 604 with no problems either...
