would this be ok on a 602 or would it be too much. 750 with 850 base plate gas Stealth 4 barrel on gas?
carb question?
maybe if your racing at Syracuse that will work but there will be no throttle response for normal short track racing with that setup
Brad
actually the base plate used on the 650 thru 800 is typically 1 11/16
carburetor size is rated at the venturi-----650=1.25 >>>700=1.315>>>750=1.375 etc. etc.
the base plate size doesn't change until you get over 800Last edited by brad hibbard; 04-04-2014, 11:10 AM.
