2010 mastersbilt smack wont turn!!!!
  • burgessracing
    • Oct 2011
    • 20
    I have a 2010 mastersbilt smack and I cant get it free enough getting in the corner or center off. This weekend I had this setup springs lf 450 rf 275 on bump, lr 175 14 inch rr 225 53.8 left, 50.8 rear 45 lbs wedge crate class ride heights lf 3 7/8 rt 3 3/4 rr 7 1/2 lr around 8 right bars rolled back 1 inch car would not turn in without braking hard track was hammer down wide open all the way around
  • keeks
    • Oct 2008
    • 687
    I would look at the LR ride height for one. Book asks for 7 3/8 - 7 5/8. I might look at 8" once it got slick.
    • burgessracing
      • Oct 2011
      • 20
      The car acts like it never slips the left rear. When the track gets slick we are real good but we are terrible when it is heavy. and it gets worse if i have a good left tire on. we have been fastest with zero left wheel. thanks for the reply ----if i run 7 1/2 lr i will be square across the back ----same ride height on left and right what wedge would you try to run
      • keeks
        • Oct 2008
        • 687
        I can't comment at all on bite or percentages. I don't have scales. Next years investment.
        Where are you running your J-bar? And your bars?
        Pretty sure a crate car is gonna need to be looser to free things up because of the lower hp.
          If you are off the gas on entry, put more rf spring in it to fix entry.
            My guess is you've got your j-bar way too low on the pinion side. For a crate motor it needs to be about an inch ABOVE the pinion to get it to turn when the track is fast.
            • keeks
              • Oct 2008
              • 687
              If you go that high on the pinion, do you still keep your baseline setting on the frame? Or move it up accordingly as well? I'm guessing it stays the same on frame.
              • drtrkr244
                • 1024
                Yes, leave it the same on the frame. Your driver should def notice that change.
                Also, try 200/225 on lr if its too tight off the gas or add more bite!
                • burgessracing
                  • Oct 2011
                  • 20
                  This weekend the car was tight on throttle. It would not turn in and the track was hammer down---never lift throttle!!!! the bars are right upper----top hole, right lower--- top hole, left upper standard, left lower---top hole. pinion is 1/2 inch from bottom( 2 clicks up) frame at 9 1/2 inches rearend is 15 7/8 over we have added more bite and it gets much worse everywhere-----tight all over track!!
                  • burgessracing
                    • Oct 2011
                    • 20
                    Matt----please give me your baseline setup that you would recommend leaning toward the free side----our shocks are new integra double adj set up for our car by WAR. we are on bump on rf. --- on the pinion we are on 1/2 inch from bottom which looks to be level with driveshaft---- all help is deeply appreciated since we have not been able to get the car really free all year long unless the track gets slick.
                    • JJ128
                      • Jul 2011
                      • 92
                      I will leave it to Matt49 or MasterSbilt_racer to help you with a complete set-up, as I am certainly no expert. But I will say from my experience with the same car as yours that your biggest problem is the J-bar rake. Depending on what length bar you are using, you either have way too much rake or way, way, way too much rake. You probably also don't want to go over 15.750" from 90/10 plate to center of RR frame rail on a heavy track. (Fixing your J-bar angle should also get you closer to the 15.750", but you will still have to adjust after setting J-bar.) I am surprised that you haven't damaged the roof with that set-up on a heavy track.
                      • HuckleberryB4
                        • 220
                        What bump are you on? What spacing? I run a low HP motor and have been playing quite a bit with the RF bumps and spacings. I noticed if I get too aggressive with the engagement of the bump, I have the same problem you do. It's not that my RR won't rotate, it's that my LR keeps too much drive in the car while on the bump.
                        • bb14
                          • Jan 2008
                          • 136
                          I agree with Matt. Keep raising the jbar on pinion until it is to free to drive and then adjust.
                            I agree. Saying you have a bump is like saying you have a spring. That said. The j bar is the problem.
                            • Garrettshurling
                              • Aug 2010
                              • 72
                              Agreed. We have a track around us that stays bolted down and I start 1" above the pinon
                              Owner/Blogger/Crash Test Dummy
                              www.nextlevellatemodel.com
