been working on putting this car together and just put it on ground and set ride heights with a 602 motor but the bottom of the oil pan is only 1 1/4 inches off the ground which will never work. Can anybody tell me what is going on here? It has the 96 style spindles on it which are 11" lf and 10 1/2" on rf
01 grt front end question
Measure the distance between the lower control arms, it's either 18" or 19", I'm suspecting it's the 19" which use's another front ride hieght.
ok there is only one hole on frame bracket for engine plate to mount but two holes for side to side. the engine is level. the rf lower arm is 17 5/8 long. the right side frame rail is 4 1/2 inches off the ground. would the 09 spindles help my situation or the MB smackdown ? Also my top arms are sitting at about 30 degrees
Measure between the bolts that hold the lower control arms to the frame will be either 18" or 19".Originally posted by mrt#9 View Postok there is only one hole on frame bracket for engine plate to mount but two holes for side to side. the engine is level. the rf lower arm is 17 5/8 long. the right side frame rail is 4 1/2 inches off the ground. would the 09 spindles help my situation or the MB smackdown ? Also my top arms are sitting at about 30 degrees
You likely have an older mid-plate that only has one hole per corner. The other ones have 4 up and down in each corner to adjust hieghtOriginally posted by mrt#9 View Postok there is only one hole on frame bracket for engine plate to mount but two holes for side to side. the engine is level. the rf lower arm is 17 5/8 long. the right side frame rail is 4 1/2 inches off the ground. would the 09 spindles help my situation or the MB smackdown ? Also my top arms are sitting at about 30 degrees
Call GRT with chassis number to double check me, but use a 3.625" front ride hieght and see if that don't look right. I pretty sure you have that off front end that was used for a year or 2 as an option.Originally posted by mrt#9 View Postyeah it is 19" between the bolts and yes I have the midplate with one hole per corner
Does it have a long RF upper shock mount as in it's long as compared to the other cars?
Like I said call GRT and get the basic set up sheet for that car number, but if I remember correctly it should have a 19" RF lower and a 15.625" LF lower but it's been 14 years so.......
I believe that is one of the cars that the front end of the car is also built out of .120 wall tubing for most of the front end. Personally I'd want to change a bunch of stuff on that car, if you have some racing experience, but if not it's likely decent enough to get you some seat time before doing some updates.
Ok thanks I will. I'm all for making changes to help go fast if you have more info. I got nearly 30 years of driving but most of it was in a rayburn and a swing arm mod don't know a lot about four bars. I been out for a few years and decided to get back in. Lol
