Well, for starters you will need to cut off the RF upper shock mount (Left one is fine) and install a new short one and replace the RF upper control arm to a 8.25". You will crash the new shorter control arm into the shock top if you don't. You may need to go shorter then 8.25" to get the correct camber so determine length off if you can get the camber or not. You will also pretty much need new one piece lowers to get more travel on the RF as it will be borderline with a older Std 2 piece lower control arm set up as the lower shock mount is likely too high and doesn't have enough exposed shaft on the RF at ride hieght.
I'd also update the 4-link brackets to the newer smaller 1/2" holes, the brackets you have are too big an adjustment. You may also need to raise the RF main rail as it's likely too drag, if it's a square tube car it's not overly hard.
Those are some things off the top of my head.
