Lead on LR tube
  • twisterf5
    • May 2012
    • 334
    Lead on LR tube
    i am seeing this allot more. but is it not a danger to run it there or is the gain worth it.
    By many rules packages, this practice is not legal. If mounted properly, there would be no risk.
    • 12doublej
      • Jul 2014
      • 31
      What about un-sprung weight being a bad thing?
      • hammond motorsports
        • 269
        I have been building Steel W-5 axle tubes and Steel 4 link cages for more info call 563 659 1153 thanks Dave
        http://www.facebook.com/pages/Hammon...26044754164488
        • Bmod141
          • 46
          12doublej - I was wondering the same thing!
          • a25rjr
            • 3774
            Im sure someone will start running dual "brake calipers" on the lr.
            Turn LEFT, Vote RIGHT!
            • RCJ
              • Nov 2007
              • 509
              When it's up on the bars and off the spring isn't the left corner of the car all unsprung weight?
              • 12doublej
                • Jul 2014
                • 31
                Yes, I guess it is RCJ....
                • fastford
                  • 4059
                  mine never gets off the spring, but for your question, with angle in the bars , i think there would be some type of a mechanical spring effect, now if the bars went strait up and down, then it might act as a solid unit.
                  • a25rjr
                    • 3774
                    I was told by a reliable source that it was Bloomers go-to adjustment for the feature esp, the last half of last year. of course, its illegal now in Lucas.
                    • sidewinder69
                      • Sep 2016
                      • 95
                      What size weight would be reasonable
                      • TheJet-09
                        • Jul 2013
                        • 1616
                        I see Keyser makes an actual clamp for mounting lead to an axle tube. Hopefully they didn't make too many! But at the same time, I bet a lot of the stuff that is now illegal in Lucas and WoO is still being used at the local level...they don't tech the cars and aren't looking for things like that (unless someone ratted you out).
                        • sidewinder69
                          • Sep 2016
                          • 95
                          Can someone explain the theory behind it
                          • Flyin Iowan
                            • 558
                            mark bush tech article in dirt late model magazine talks about it if you can get a hold of a copy
                            Chris Zogg
                            • sidewinder69
                              • Sep 2016
                              • 95
                              what issue ?
