Lead on LR tube
  • JustAddDirt
    • 1893
    #31
    It works. At least the wheel weights do.
    • grt74
      • Jul 2009
      • 1380
      #32
      Originally posted by Kromulous View Post
      Steel Axle tubes, and steel birdcages, how much added weight would that be?
      I suppose you could line the inside of a steel tube with a smaller tube, and pour lead between, that would be an idea. Say fill in a 1/4" gap with led?
      I have always wondered about this, adding to the LR axle, wieght but have never tried it.
      cup has a rule on this, they caught guys lining the tubes with tungsten,this is an old asphalt trick
      • Stede Bonnet
        • Sep 2016
        • 325
        #33
        Lining the inside of the tube makes sense, having a #40 wheel cover, that's reckless endangerment. As far as going from 900hp down to 400hp, why not a restrictor plate, I know Jay D!ckens experimented with it.
        Politically Incorrect.
          #34
          I'm telling you, boys, this is all going the wrong direction and it's going there fast! We've had rules for years to limit how light we could make things and now that somebody has figured out a little trick (AKA, understanding the laws of physics), we're going to end up with rules on how heavy we can make things. The box is getting smaller every year. This is turning into NASCAR right before our eyes and it's a matter of time before we're just told "here are the rear end components you can use and here are the two places (which we own both) you can go to buy them".
          • zeroracing
            • 1014
            #35
            Matt49, could not agree more, changing classes looks more appetizing every day.
              #36
              I am with you guys.
              • MBR Performance
                • Nov 2014
                • 199
                #37
                I love the innovation part but what I don't like is the incurred cost. There is one person right now that has a LR tube made from tungsten. The price for that is $5500.00 now I'm not saying you need to have it but you are racing against it. There needs to be some limitations but not to the extent of NASCAR.
                  #38
                  Most of the folks on here are not racing against it. And, if the rules are no so limiting, you could get the weight cheaper. That is, if you really need that kind of weight.
                  • Stede Bonnet
                    • Sep 2016
                    • 325
                    #39
                    Decentralized Power is best.
                    A fool and his money are soon parted, a $5500 axle tube is foolish. Like MBracer said there are cheaper ways to get that kind of weight. I raced karts for several years and there are never a shortage of dopes willing to buy the secret component, but I've outrun them too on a 3rd the money spent. Matt49 is right too, the rules are moving to fast and getting a bit far reaching, this is why I was never in favor of centralized power in DLM world.
                    The Unified Rules Committee(aka WRG) has found daddy's gun and is waving it around like an idiot on crack.
                    • Lizardracing
                      • 839
                      #40
                      Years ago I was a tech inspector for UMP and I quit because when I enforced rules I got call from UMP complaining about it. I wasn't willing to go against my principles for a measly $50 a night. The company that supplied the transponders wanted us to put them on the LR or RR axle tube and not that body or chassis because they said they find they are more reliable and less prone to vibration failure.
                      Ballast may be SAFER bolted to the axle tube!
                      The only reason WRG/UMP/(alphabet governing rules) get that kind of power over the racer is because the racers keep showing up anyway. They might complain and whine and throw temper tantrums yet they continue to show up and give them money. The power is in the racers and fans to change by working together as a group and when they as a group finally stand up and say enough is enough then taking your money and giving nothing back will continue. Behaviors gone unchecked will continue.
                      • RCJ
                        • Nov 2007
                        • 509
                        #41
                        If you were on a hard tire on a slick slow track, I can see unspung weight helping build tire temps.It works or flexes the tire differently.
                        If you told a racer to hang 20lbs in front of the l/r, as low and as far left as possible.First thing he's going to say is" that going to kill all my side bite".If you say "Here is a secret 20lbs spacer your superhero is running" you can sell that.
                        • Stede Bonnet
                          • Sep 2016
                          • 325
                          #42
                          You are a wise man. Perhaps a racers union should be formed?
                          There is a difference in hanging weight low/left on chassis than on the axle. Low/Left on chassis will effect weight transfer and body roll, on the axle its more or less fixed/dead weight. Trends swing like pendulums, from one extreme to the other, in my early days having a lite weight axle tube was thought of as a "Must" now it seems we've gone to far with the sprung/unsprung theory and are swinging back the other way. You stay around the sport long enough and lots of things come and go, its one of the things that keep me interested. Leafs to swing-arm, swing-arm to 4 link, 4 link to swing-arm and back to 4 link. This is the way its always been, seeking something a little better, but it always goes too far and then the trend reverses. Sadly now we have this regulation over reach that wants to bring all the innovation to an end and go cookie-cutter, which is boring and expensive. I'm for safety, but it seems 99% of us are being left out of the conversation and being saddled with 99% of the bill. The wheel cover/spacer deal I understand because it endangers everyone, more so the cover. The fire suppression systems should've been given a grace period for compliance, IMHO. The mandatory sfi 29.2 rated stuff are the biggest ticket items for sure and springing ALL this at once is gonna have an impact on at least the early shows for next year locally I'm sure. The seat thing pi$$e$ me off, because there is data coming out that suggests some of these seats are directly related to increased concussion injuries. I've seen 2 roll overs this year, where both drivers had all the FC/HANS/SFI-39.2 latest and greatest. Neither rollover was spectacular and didn't involve a hard impact, but both drivers received concussions with lingering effects and resulted in one retirement. Now this "Unified Rules" bunch is telling me I have to strap myself in to a seat that will likely injure me and I don't even have to wreck to get injured because of it... I'm not happy.
                          What should have happened as a ramp up, is to have rules on fuel lines and couplings and enforce that, with a (#50)weight break if you install a 39.2 fuel cell and (#25)weight break for the FC seat. Use market forces and personal choice to drive the change. Unilateral rule/law enactment is a dictatorial style move and I don't like it.
                          • Modified18
                            • Nov 2014
                            • 6
                            #43
                            So how are these guys melting the tungsten down and containing it to make whatever shape the want? Quick research show melting point of tungsten to be around 6,200 degrees. Thanks
                              #44
                              You don't. You machine it.
                              • manwplan
                                • 351
                                #45
                                The unified rules committee is as much Lucas as it is WRG if not more. Remember Lucas is the group that led the suspension rules last year and Lucas is who is leading the is current deal. WRG doesn't really have a spine and they are along for the ride to do whatever Lucas wants.
