Why do you need one, if you can get the LR to Travel 15 plus inches? The RF maxed out is gonna stop it before the chain ever will. I think that's the theory on no chain.
Limit chain
Once you have all that bar angle, it is going to go on until something tops out.Originally posted by Kromulous View PostWhy do you need one, if you can get the LR to Travel 15 plus inches? The RF maxed out is gonna stop it before the chain ever will. I think that's the theory on no chain.Modern Day Spec Wedge Racing
Let me guess...bent bird cage ears, busted transmission seal. Been there done that. I've considered running a "backup" chain and keeping it about 1/2 longer. I'm personally not worried about what the rules say until somebody actually techs my car.Originally posted by GRT62 View PostBroke a chain mount one night and it over indexed the bars and tore a bunch of stuff up. RF pinned down definitely didn't stop it from climbing the bars.
Gas is a fluid, however it is not a liquid. There's a huge difference in the states of matter.Originally posted by MasterSbilt_Racer View PostGas is a fluid. If you have a piston and a fluid, you have a shock. You are not allowed a shock on the limiter.
Oil used in a shock absorber is a liquid.
The "gas" limiters will function properly on dry shop air, they do not require nitrogen per information I have been supplied.Last edited by Renegade Cust Susp; 03-01-2017, 10:19 PM.Broc Burton
go.fast.crs@gmail.com
So if a rule book says, A brand of fuel (gasoline) is legal does that mean methanol/alcohol is inherently illegal? That logic is a little off baseOriginally posted by stock car driver View PostIf it says one droop limiting chain then that would mean a CHAIN only to me, no other contraptions in between....
If more was legal it would say droop limiting chain and device or chain and $$$Broc Burton
Not hard at all as long as the shock components are robust enoughOriginally posted by MasterSbilt_Racer View PostI don't think it would be that difficult to put a bumpstop in a shock and have it not harm the piston.Broc Burton
Only if you want the under rail to be the limiting factor. Best to run something adjustable (chain limiter or shims/bumps on under rail). LR travel is a pretty noticeable adjustment to those who use it.Originally posted by 95rayburn View PostSo if you have a under slung chassis you don't need to run the chain?
All fluids have a viscosity. Including all gasses. You can make a shock with zero liquid inside.Originally posted by Renegade Cust Susp View PostGas is a fluid, however it is not a liquid. There's a huge difference in the states of matter.
The "gas" limiters will function properly on dry shop air, they do not require nitrogen per information I have been supplied.Modern Day Spec Wedge Racing
Exactly what happened actually cracked the ears at the front of the mount. You better have something to stop the indexing force weather it be and under slung or a chain. I have another question also I've seen the Earnhardt technologies pieces, and I'm aware they offer one gas or you can get it with a spring. I thought we determined years ago that you need a positive stop for consistency, chain is going to stop in the same place everytime. Can this be said about these pieces ETG. has developed?Originally posted by Matt49 View PostLet me guess...bent bird cage ears, busted transmission seal. Been there done that. I've considered running a "backup" chain and keeping it about 1/2 longer. I'm personally not worried about what the rules say until somebody actually techs my car.
There is a difference in slowing/dampening the travel just before the limit and using something like a spring that can/will pull the car down and let it lift back up (pogo'ing) with a slight change in LR traction like driving across a slick spot. The less dampened or softer spring rate used with increase the chance of this happening and likely hurt the car way more then anything you will gain.Originally posted by GRT62 View PostI thought we determined years ago that you need a positive stop for consistency, chain is going to stop in the same place everytime. Can this be said about these pieces ETG. has developed?
Now do some of these devises work, some do and some don't and some are legal and some aren't depending on where or what you race. Sadly your going to have to test it yourselves.
