Limit chain
  • Kromulous
    • 3008
    Why do you need one, if you can get the LR to Travel 15 plus inches? The RF maxed out is gonna stop it before the chain ever will. I think that's the theory on no chain.
    Just say no...
      • 14324
      Once you have all that bar angle, it is going to go on until something tops out.
      • GRT62
        • Jan 2014
        • 177
        Broke a chain mount one night and it over indexed the bars and tore a bunch of stuff up. RF pinned down definitely didn't stop it from climbing the bars.
        • fastford
          • 4059
          i have not used a chain since we got on the under slung frames now , but i made a bump stop type thing to go on the under slung frame that can be adjusted to control hike like a chain, is that legal?
          • Matt49
            • 3123
            Let me guess...bent bird cage ears, busted transmission seal. Been there done that. I've considered running a "backup" chain and keeping it about 1/2 longer. I'm personally not worried about what the rules say until somebody actually techs my car.
            • a25rjr
              • 3774
              I don't think it would be that difficult to put a bumpstop in a shock and have it not harm the piston.
              I was thinking the same. Both cars had Penskes and were underslung.
              Turn LEFT, Vote RIGHT!
              • Renegade Cust Susp
                • 349
                Gas is a fluid. If you have a piston and a fluid, you have a shock. You are not allowed a shock on the limiter.
                Gas is a fluid, however it is not a liquid. There's a huge difference in the states of matter.
                Oil used in a shock absorber is a liquid.
                The "gas" limiters will function properly on dry shop air, they do not require nitrogen per information I have been supplied.
                Broc Burton
                go.fast.crs@gmail.com
                  • 349
                  Originally posted by stock car driver View Post
                  If it says one droop limiting chain then that would mean a CHAIN only to me, no other contraptions in between....
                  If more was legal it would say droop limiting chain and device or chain and $$$
                  So if a rule book says, A brand of fuel (gasoline) is legal does that mean methanol/alcohol is inherently illegal? That logic is a little off base
                  Broc Burton
                    • 349
                    Not hard at all as long as the shock components are robust enough
                    Broc Burton
                    • 95rayburn
                      • Sep 2012
                      • 162
                      So if you have a under slung chassis you don't need to run the chain?
                      • Matt49
                        • 3123
                        Only if you want the under rail to be the limiting factor. Best to run something adjustable (chain limiter or shims/bumps on under rail). LR travel is a pretty noticeable adjustment to those who use it.
                          • 14324
                          All fluids have a viscosity. Including all gasses. You can make a shock with zero liquid inside.
                          • RCJ
                            • Nov 2007
                            • 509
                            I remember Bloomer having to take a devise apart and show that there was nothing inside of it.I wonder if there was just no fluid in it?
                            • GRT62
                              • Jan 2014
                              • 177
                              Exactly what happened actually cracked the ears at the front of the mount. You better have something to stop the indexing force weather it be and under slung or a chain. I have another question also I've seen the Earnhardt technologies pieces, and I'm aware they offer one gas or you can get it with a spring. I thought we determined years ago that you need a positive stop for consistency, chain is going to stop in the same place everytime. Can this be said about these pieces ETG. has developed?
                                • 2020
                                There is a difference in slowing/dampening the travel just before the limit and using something like a spring that can/will pull the car down and let it lift back up (pogo'ing) with a slight change in LR traction like driving across a slick spot. The less dampened or softer spring rate used with increase the chance of this happening and likely hurt the car way more then anything you will gain.
                                Now do some of these devises work, some do and some don't and some are legal and some aren't depending on where or what you race. Sadly your going to have to test it yourselves.
