Bump springs
  • DEKconsulting
    • Apr 2015
    • 234
    Bump springs
    Thoughts on them and do u think they are better for ur shocks than standard bump stops? Go.
  • DEKconsulting
    • Apr 2015
    • 234
    Come on no one uses these or knows about them. I think tbey will be better for our shocks than slammin them against hard ass stops all the time
      • 14320
      Once those coil bind, they gotta be mean. And before that, they are a spring. I don't get them, honestly.
      • Punisher88
        • Nov 2014
        • 495
        Pretty sure he was just bumping the post back to the top.. since no one had replied..
        • DEKconsulting
          • Apr 2015
          • 234
          Really arguing with myself if u didnt understand that maybe u shouldnt be lookin
          • Krooser
            • Nov 2012
            • 3117
            Post number two could have used a question mark after the first sentence... that would have changed everything.
            Class of 2019
            • collateralDamage
              • Jul 2010
              • 110
              I like the linear properties of a bump spring. I like the durability of an elastomer. You can make an elastomer linear within an adequate range of travel with some creativity.
              • MBR Performance
                • Nov 2014
                • 199
                A bump spring will out last a bump stop any day
                  • 14320
                  Is durability really an issue? How do bump springs survive coil bind?
                  • LOSTRACER2
                    • Aug 2016
                    • 2
                    Thoughts on the RE suspension "bump washer"?
                    • fastford
                      • 4059
                      i use it on top of there cone bump stop, helps to keep from distorting the top. ive had good luck with anything ive got from these guy,s and there tech help is good also....
                      • 7uptruckracer
                        Are you talking seperator washer or Bellvelle stack?
                        • ALF401
                          • 164
                          I posted on here a year or so ago about springs instead of rubber bumpstops and the response I got from these pro's on here was that I was crazy. I was in a shop and saw the spring on the shock shaft and inside the spring cup. It was about the size of a valve spring. This spring may not have had anything to do with it but the guy killing the competition every weekend so he was doing something right.
                            • 14320
                            If you want to have a second stage with a 1500#, you can do that with coilovers. Then if you want a stop, rubber is better. What color underoos did that fast guy have?
                            • King1
                              • Jan 2012
                              • 354
                              I looked at a Lucas oil car last spring and it had bump springs on it. Went back today and it had pucks stacked and no bump springs. I also saw some screwed up stuff all over that thing. Interesting to say the least.
