08 smackdown updating
  • CDNRocket18R
    • 78
    I have an 08 square tube smackdown, was thinking bout getting updates done on it, like a raised crossmember, maybe rear under slung. Is there anything else that should be done, or would it be better off to just upgrade to a newer chassis. Thanks
    • 14319
    Easiest thing would be to pick up a Gen x type car. They are cheap as hell.
    • CDNRocket18R
      • 78
      How are those cars in handling compared to a smack car? And I would assume I would need new front suspension as well
        • 14319
        They steer way, way, better. You have better ground clearance. You would need spindles and maybe uppers? I would have to check my old setup sheets... The longer Smackdown rf lower is the same length as the Gen X, but the Gen X has two coilover mounts. To be safe, you would need the rf lower too.
        I promise you will find it a worthwhile upgrade.
        • TheJet-09
          • Jul 2013
          • 1616
          I ran an '07 Smackdown from 2013-2016, then picked up a '14 Gen-X for this year. A night and day difference. The easiest way to describe the difference would be to say the Gen-X practically drives itself. It seems almost that effortless. Much better front end as MasterSbilt_Racer said, and the rearend width and 4-bar lengths are different as well.
          • Krooser
            • Nov 2012
            • 3117
            What's the difference in spindle heights bewteen the two.... and how about the S7 spindles?
            Class of 2019
            • CDNRocket18R
              • 78
              How old of a gen x is to old? Any specific years
                • 14319
                To add to what Jet said, the Gen LXT can use smack bar lengths or the gen x lengths.
                For years, just find a good chassis. They are all pretty much the same.
                • TheJet-09
                  • Jul 2013
                  • 1616
                  For Krooser:
                  http://www.4m.net/showthread.php?370...e-measurements
                    I have to second or third what others are saying. Night and day difference. With the old smack front end, if you miss the rotation of the car on corner entry one way or another, you'll fight to get it straight all they way to the flag stand. The GenX is MUCH more forgiving. It steers with the front end from the center off unless you are just way out in left field on setup.
                    • RCJ
                      • Nov 2007
                      • 509
                      I updated my 08 myself.Getting the rack and bump steer figured out was the hardest part.
                      • CDNRocket18R
                        • 78
                        Would a smackdown benefit from putting a rear unslung in like the new cars to make them more ridged?
                        • TheJet-09
                          • Jul 2013
                          • 1616
                          Others probably have a different take, or certainly a better understanding, but I look at anything beyond the rear coilover mounts as merely holding up the fuel cell/body. Now if you've ever stood on the rear bumper with the car on jack stands, you'd definitely see what flex the tail section has. I like the ease of adjustability with an overrail tail section, meaning the underslung part cannot get in the way, with LR droop, etc. I think there was a time when some cars (certain Rockets) were removing the RR underslung.
                          If not already done, I think the greatest change that can be made to your car (an '08 Smackdown) is raising the center section (where the R&P bolts on). It's not hard to do. You could look into raising the right hand frame rail as well. I planned on doing that next on my '07, but moved on to the Gen-X instead.
                          • CDNRocket18R
                            • 78
                            is it just being raised up or moved back some as well. Just curious on which way to go
                            • Krooser
                              • Nov 2012
                              • 3117
                              What's an LXT?
                              Class of 2019
