i have a 06 blue front end rocket with the wide rf. no matter what the track condition is the car will not rotate on entry it just plows the front end. LF 550 RF 275 LR 200 RR225 Left 54.4% Rear 51.8% Cross 54.4%. Scale numbers Lf 601 rf 602 LR760 rr 537Short ltb in the 3rd hole. Llb 4th hole. Rtb middle hole. Rlb 2nd hole. Bars are standard lengths for rocket. J bar is 9 3/4 on the frame and bottom of pinion been in the middle also still no difference. Running a steel headed motor
Too Tigh On Entry wont rotate
Any bump stops? Is the cross member still in the original place? You are likely bottoming out and that is why it pushes. Put a 400# in the rf, rescale, and see if it turns.Modern Day Spec Wedge Racing
Yes have a bumpstop on the right front. Does not have a raised crossmember. I don't feel it bottom out. Haven't been on a 400 rf but have been on a 350 and 375.
You have 223lbs of LR Bite. That’s needs to be around 120. All that bite if you are driving in on the far that’s gonna make it push. 450 Left Front spring, 325 RF. 8 3/4 jbar middle pinion, 53.5 rear, reset all your front end and get rid of the short LRU just as basicsOriginally posted by Dirtracer18 View Posti have a 06 blue front end rocket with the wide rf. no matter what the track condition is the car will not rotate on entry it just plows the front end. LF 550 RF 275 LR 200 RR225 Left 54.4% Rear 51.8% Cross 54.4%. Scale numbers Lf 601 rf 602 LR760 rr 537Short ltb in the 3rd hole. Llb 4th hole. Rtb middle hole. Rlb 2nd hole. Bars are standard lengths for rocket. J bar is 9 3/4 on the frame and bottom of pinion been in the middle also still no difference. Running a steel headed motor
Up to about 2 years ago, I'd whole heartily agree with that but now: There are exceptions to that and quite a few actually.Originally posted by JustAddDirt View PostThat will tighten entry
1 If you're only changing the spring and maybe resetting the coilover back to the same ride hieght, then yes most of the time that's what you're going to get.
2. However if your changing the spring and adjusting the ride height load number, then you may not get the same effect. Meaning I have a 225# spring with a static ride hieght load number of say 350# and typically traveling 2.5" from ride height. So that makes my static load 350# and my 2.5" load at 912.5, but say I do this: 250 spring with a 287.5# load number, my 2.5" number is the same 912.5#. I'll pretty much guarantee that it don't handle the same. I not only changed the ride hieght therefore right side bar angles and wheel base but also the aero on the car as well as the wedge numbers.
Like I'd said I'd agree with it for the most part but you have to take into context some of these other things because we are doing stuff completely different now and looking at things in other ways and it throws a bunch of exceptions into the old rules.
Just want to say I'd agree with justadddirt I probably wouldn't stiffen the spring in his case, but you have to know how he was going to change it. I'm going to go out on a limb and guess that I believe the OP is likely racing on a fairly flat track.Last edited by billetbirdcage; 11-13-2017, 05:43 PM.
Do you think most people re-set their ride heights after changing springs? I know that I never changed a spring at the track, that I had already tried it on the scales at the shop. Usually, I had a spare already set but not every time!Originally posted by billetbirdcage View PostUp to about 2 years ago, I'd whole heartily agree with that but now: There are exceptions to that and quite a few actually.
Just want to say I'd agree with justadddirt I probably wouldn't stiffen the spring in his case, but you have to know how he was going to change it. I'm going to go out on a limb and guess that I believe the OP is likely racing on a fairly flat track.Turn LEFT, Vote RIGHT!
Sure most do, but what I'm getting at it completely isn't the same thing.Originally posted by a25rjr View PostDo you think most people re-set their ride heights after changing springs? I know that I never changed a spring at the track, that I had already tried it on the scales at the shop. Usually, I had a spare already set but not every time!
My example above: 225 to 250 with resetting coilover nut (just for shear info here to adjust it back to the same ride height you are talking .150" of an adjustment up on the coil over nut to get it correct assuming both springs are indeed 225 and 250 and linear).
225 = #350 static load #912.5 dynamic
250 = #350 static load #975 dynamic
Mostly you changed the dynamic loads from ride height down and most likely lessened the travel on the RR.
If you did what I said with replacing the 225 with a 250 but altered the static load
250 = #287.5 static and #912.5 dynamic
I took some liberties here cause obviously these changes don't exactly mean the RR is still going to go to that imaginary 2.5" dynamic travel
All three of these are going to react differently which was the point I was making, the rate of the spring is only one factor. Again not saying anyone is wrong but depending on what you do, you are likely to get a different reaction.
Is there a particular scenario where I would actually want to change the RR spring and change the static load on that spring? Would the goal be just to free entry a little while maintaining the tightness from center off under full load? But then playing devil's advocate here...aren't there easier, simpler, or better ways to achieve that?
Ask the XR1 guys who's RR corner keeps getting lower as the night goes on and they keep carrying spring rubbers to the rr.Originally posted by Matt49 View PostIs there a particular scenario where I would actually want to change the RR spring and change the static load on that spring? Would the goal be just to free entry a little while maintaining the tightness from center off under full load? But then playing devil's advocate here...aren't there easier, simpler, or better ways to achieve that?Modern Day Spec Wedge Racing
I don't personally know anyone on XR1 who are changing things there anymore, the other Rockets definitely though. I dunno what the difference is on why one and not the other. My friends running and winning on XR1 still aren't chanfing anything bc Rocket told them not too lol. Now that being said the only change I was told was recommended was being told to take rounds out the RR as an adjustment. That and the stagger. Which Maybe another topic for discussion the low stagger makes alot more sense for driving a car straight ahead then the 4" we have always just stuck with
