Digressive stack, that’s been around for a bit I think genesis had something like that going on but I couldn’t figure out what the use for it would have been, it had a lock out collar that had the one spring disengaged until a certain point of travel and then from there on, it was the stacked rate. Almost looks like in this one from advanced it wasn’t a lock out collar it was a pre loader with a spring in it with another spring stacked on the mix. Same concept of digressive rate but different mechanisms.
Black Diamond
I know about these and this isn't it after I showed the guy who had me do digging Its some form of mechanical linkage between the RR and 5th coil and its supposedly not a cantaliver concept so who knows.
No....Connects at the RR shock and Shock on Lift Arm. I havent heard or seen anything like this. Supposed to be derived from a Formula 1 concept and no not FRIC stuff
The reason this rules existOriginally posted by modman1010 View PostPretty sure bloomer messed with this a couple years ago and they made him take it off
12.21 Shocks and Springs
A.) Shocks must be constructed of aluminum or steel. Canister shocks are permitted.
**1. The only external connection allowed to the shock is a single hose to a single remote canister with the option of a compression adjuster in the canister.
2. Compression adjuster and/or canister cannot be mounted within the reach of the driver.
**B.) No cross connected shocks are allowed.
1. The only external connection allowed to the damper is a single hose to a single remote canister with
**2. No Inerter style dampers, either mechanical or hydraulic, or other type of primarily acceleration
sensitive damping devices not permitted.
Lots of misconceptions and theories to what everyone called the 20,000.00 shocks he was using.
Honestly don’t know. Just in the intel gathering phase. He runs some big shows and struggles but local stuff really dominant so seems like it might come on and off the car. Sounds like it could be a cross connected shock
Originally posted by Mr.Kennedy777 View PostTop or bottom of the shock?
Interesting...The other car I made the post about was running too....
Originally posted by missile07 View PostI tried to post the pic but there is one floating around of EPJ on the jacks without his complete right side and the right rear has either a take up spring or something similar to the contraption that ARS sells.
