Lift Sticks/5th & 6th coil combos
  • BNaylor91s
    • Oct 2016
    • 23
    I have been looking at lift sticks along with having conversations with other racers about combos on 5th and 6th coils. I cannot find a lot of information on these lift sticks. Does anyone have some insight on them?
    It uses a series of urethane bushings to create a progressive spring rate. Allows you to tune rate and inflection point where the rate changes.
    • zeroracing
      • 1014
      I did some testing on them before they came out. They are tunable, and yes very progressive. From the drivers seat I felt the car got in and through the center better. The reaction of geting off the gas seemed smoother and it felt from the driver seat it kept the rear tires stuck better. Drive off might have been a little better but the car felt better and smoother in, that was the most notable change. Due to the better entry I’m honestly not sure if my better drive off was from the stick or from higher center of corner speed. I don’t think thy are overly pricey compared to many other products and worth a try. Still run a 5th coil shock.
        • 2020
        So, do we want a progressive rate or a digressive rate with a spring and dump valve or just a linear spring? Seems people can't make up their minds, LOL.
        ^ rhetorical question ^
        Billet shakes his head, then scratches it, then shakes it again, then goes on with life......
        • TheJet-09
          • Jul 2013
          • 1616
          Did I read correctly in an add for one, that they need servicing (replacement of bushings) around 250 laps?
          • dirtrace09
            • Aug 2007
            • 746
            Zero did you choose to keep using it or go back to a 5th/6th coil spring shock combo? Did you change the bushings to a different set for rate and if so was that based off of travel or feel?
            • Burke1118
              • Mar 2018
              • 222
              Originally posted by billetbirdcage View Post
              So, do we want a progressive rate or a digressive rate with a spring and dump valve or just a linear spring? Seems people can't make up their minds, LOL.^ rhetorical question ^Billet shakes his head, then scratches it, then shakes it again, then goes on with life......
              Lol.... bloomer was dominating with an inerter 5th coil and now the trick rocket 5th coil shock has literally no valving? Apparently only extreme opposites work on the lift arm. Run a normal shock and a linear spring and you will be giving up 2 tenths..
              • Kromulous
                • 3008
                I "heard" Bshepp has been running one of these Liftsticks...
                I like the idea because of the rebound characteristics of the poly / rubber. You just reduce the reaction of all the active coils of the spring. I had some Lucas guys tell me that they run a 200lb spring stuffed full of spring rubbers, now what rate is that who knows, and i couldn't get anymore info on it.
                Just say no...
                  I think the question is: Do you want to "absorb" the torque or "push back". Metal springs and rubber can do both but the rubber won't push back as hard. At least I think that makes sense.
                  • Doc88D
                    • Jun 2012
                    • 170
                    I believe it may be more about removing the "harmonic vibrations" than anything else.
                    Doc
                    Facebook.com@DowdyRacing
                    • Kromulous
                      • 3008
                      Now that's another good point, harmonics. Whole new bag of worms there.
                      I cant wait till i hit that Lotto, i am gonna test this stuff all day long, 7 days a week LOL. Some many things to tinker with on these cars.
                      Just say no...
                      • MLR19
                        • 475
                        I think the whole idea is something else to sell, that invariably ends up on the shelf when you go back to the std shock/spring arrangement.
                          I think we have a winner.
                          • MLR19
                            • 475
                            The trick is to try it and then sell it before everyone else realizes it does't work.
                            • let-r-eat
                              • 2319
                              Gimmicks are worth a boatload of $$$$. They are everywhere!
                              BUCKLE UP NOW, YA HEAR?
