I only got to run it a few times,our season ended early. I ran it twice, same rate just the standard off the shelf they sent. Then went back to a traditional set up. Part of the thought process is like on the pull bars they need to be progressive, these should be also. If they should or not is a debate. With our limited run time I’m not swearing it’s the best thing ever, it did seem the car was smoother on entry and did not break the rear tires loose if you entered a little hard. That probably was due to the 6th coil effectively being back further than it was prior, and the bump stops being used not a linear spring.
Matt49 is also correct in that the bushing pull bars don’t bounce back as hard as the spring ones so the same theory was moved onto the 5th coil.
I am getting ready to debut a new car this upcoming week if everything goes as planned on the list of items to test again is the lift stick. Run traditional then it again. I will tune the feel based upon driver feel to a point but also the load curve from the spring machine. We will compare the curve to travel seen/what the driver likes or dislikes and attempt to form a good correlation.
Also I don’t remember the expected life on them off the top of my head but bushing pull bars typically have short lives.
