Rocket short bar brackets
  • shadowj38
    • Jul 2011
    • 161
    I recently swapped my LR spring out for a 16" 125 barrel spring. I like the way the car feels now but I've noticed I need to be much smoother with the pedals because the car seems to react much faster now. The car came with the short bar brackets on both top and bottom of my Lr. I've been looking at a bunch of cars in the pits and pictures of cars for sale on the internet and it seems not many people run these brackets anymore. Atleast not both of them. I've been thinking of taking them off this year to see what it does. What are some pros and cons of running these vs. Not running them? This is on a blue front rocket. Thanks.
  • phenom08
    • 228
    What kinda motor, what size tracks,
    • shadowj38
      • Jul 2011
      • 161
      430 open steel block. 3/8 mile tracks
      • phenom08
        • 228
        I would start with the long top bar, and short bottom bar with 13.75 drop
        • shadowj38
          • Jul 2011
          • 161
          Kind of what I was thinking of trying. Didnt want to take both off and change too much. Thanks
          • shadowj38
            • Jul 2011
            • 161
            Phenom08 can you explain your reasoning? I'm trying my best to learn and understand these cars. Thanks
            • phenom08
              • 228
              We run the short top bar with crates or small tracks. Car will turn more when u pick the throttle back up. The long bottom bar can make it hard to climb the bars if there's no moisture to put the lr in
              • shadowj38
                • Jul 2011
                • 161
                Thanks for the reply
                • Mopar DLM
                  • Aug 2012
                  • 217
                  what are the lengths of the long and short bottom bar?
                  • shadowj38
                    • Jul 2011
                    • 161
                    I'm not positive on this, I'll have to check in my book but I believe 15 1/4 for the short bar. I'm not sure on the long bar. I don't believe my book says.
                    • Dirtmod13
                      • Jan 2014
                      • 245
                      I think top bar is 18-18.25 if I recall
                      • Burke1118
                        • Mar 2018
                        • 222
                        Length of bar has far less effect than angle. Shorting the left top 2” would have a smaller effect than just going up a hole. I remember looking into 16 vs 15” lower bar, and after plotting it out on my computer, it made something like a 1/16” difference in steer and maybe a degree of indexing difference. No driver in the country could feel that.
                        • 95shaw
                          • Nov 2007
                          • 205
                          The starting angle at ride height may be an even bigger effect of short bar vs long bar.
                            • 2020
                            OP should be talking:
                            LRU bars at either 18.25 or 16.75 with shortener bracket
                            LRL bars at either 17.0 or 15.0 with shortener bracket
                            Assuming 25 degree static upper and 12 degree static lower bar angles and almost 5" of travel at cage (this brings the long upper bar close to 45 degree's at full hike), these are the following rollsteer, index and thrust angles at full hike (note this is only measured at the cage not at the wheel)
                            18.25 LRU and 15.0 LRL:
                            2.715" of steer
                            38.87 degrees of thrust
                            9.36 degrees of index on cage
                            16.75 LRU and 15.0 LRL:
                            2.781 of steer
                            40.16 thrust
                            10.174 index
                            18.25 LRU and 17.0 LRL
                            2.645 steer
                            37.87 thrust
                            10.259 index
                            That being said: While it doesn't look like much of a change I don't know a driver yet that hasn't been able to feel anyone of those changes.
                            #note: when bar length was changed, the static angle was not changed still the 25 or 12 degree static
                            • Dirtmod13
                              • Jan 2014
                              • 245
                              Billet, What program did you use to mock up the distances and calculate index?Sent you a PM
