Race Fan?
  • dkibel
    • Sep 2015
    • 28
    Well im glad it wasnt just me. I was at Lburg saturday night as well and my water pump bolts came loose. We had a water pump failure the week before and just used Lburg as a shakedown. After inspection this week we had a bit of runout on the water pump pulley that i thought was causing the bolts to come loose.
    • Kromulous
      • 3008
      Dkibel, you running a Race Fan as well?
      Just say no...
      • dkibel
        • Sep 2015
        • 28
        Correct, i have not been impressed. I put my 17" steel fan back on it this week.
        • Kromulous
          • 3008
          Ended up getting a chance to work on it last night, took a look at the belt and all the little V's in the middle portion of the belt was wore down flat. I think it was just wore out, via dirt and being old etc. It may of been the original belt, not sure.
          I ended up making a bunch of shrouds etc to shield it somewhat, they should help, hopefully.
          Just say no...
            • 2019
            Put one from the RF lower arm inner mounting point forward to the radiator area and up to the main frame rail (4" or so tall), this will stop a lot of dirt from going to the rack and balancer area
            • eight r
              • 91
              I had water pump coming loose as well...turned out the fan was out of balance...if running a 4 blade race fan you will have extra mounting hole for adding other blades...make sure it is balanced out across from one another
