Left lower adjustment
  • TwistedFrame21
    • Oct 2012
    • 54
    When moving the left lower down on the cage to say 5 1/2 from 4 1/2, should you reset your droop load? I made that adjustment tonight and rest it and I couldn’t tell much of a difference
    • 14304
    Did you maintain your install pin to pin load?
    • TwistedFrame21
      • Oct 2012
      • 54
      I am running a single 100lb spring, static load was the same until I adjusted the droop load which in turn would have altered the static load
        • 14304
        Ok. That is what I was assuming. Loss of static load is going to be an opposite adjustment compared to the bar change.
