XR1 driveshaft length w/Falcon trans
  • racert22
    • Jun 2012
    • 795
    Anyone know the driveshaft length for an xr1 rocket with a falcon transmission?? Trans is regular falcon not roller slide also
  • racert22
    • Jun 2012
    • 795
    No one knows?? H*lluva tech forum lol
    • keeks
      • Oct 2008
      • 687
      Too many variables. Get out the tape measure. Give Rocket a call.
        • 14310
        You asked for a Falcon
        Lol
        • JLyons
          • Feb 2014
          • 17
          I have a B/G car with driveshaft in it, I’ll save you the hassle and you bring me the XR1 and I’ll send you with the B/G and I’ll deal with the driveshaft. 😂
          • keeks
            • Oct 2008
            • 687
            ^^This is the kind of out of the box thinking that this forum is best at.
            • MachineMasters
              • Oct 2010
              • 74
              I would guess a 37" shaft would work.
              Or swap for that B/G car like the above posted said
              • Lizardracing
                • Sep 2009
                • 839
                Falcons and Berts are the same length as the Saginaw 3 and 4 speeds they were developed to replace. The Brinn(most latemodels) are 2" shorter so minus 2" from what ever Rocket set up book says. I'd guess 37" as I think most SLM are 39" with a Brinn,
                  • 14310
                  The Bert is the short transmission. Brinn is the Saginaw replacement. I don't know anything about Falcon.
                  I'm fairly certain an XR1 takes a 38" shaft with a Bert.
                  • Lizardracing
                    • Sep 2009
                    • 839
                    Correct. I spoke incorrectly.
                    Falcons are popular in the Modifieds and a few SLM around my neighborhood. They are something like a cheaper, Winters made version of the Bert. They have a roller bearing in the housing instead a bushing and require a hardened yoke for best life. Like anything else, they work well if you take care of them. I've had mine for nearly 10 years. I bought it used but had a tooth broken on the input shaft and the previews owner complained of it jumping out of gear. I ground and smoothed the gear tooth and adjusted the shift forks and shifter detents and it's been flawless for me. I have a spare rebuild kit but it's still on the same set of clutches.
                    • CCHIEF
                      • Jul 2014
                      • 399
                      XR1 with std Gen2 Bert trans takes a 37-37.5" (37" preferred) shaft. Gen2 is 21.752" from bell flange face to end of tail shaft. Measure or find your trans length and cypher! No idea how long a Falcon Trans is. I do believe they are rather long, so I'd ESTIMATE a 34-34.5" shaft in an XR1.
                      • collateralDamage
                        • Jul 2010
                        • 110
                        The standard slip-yoke Falcon is about the same length as the Brinn transmission. A Falcon roller-slide is the same length as any Bert transmission, which is about 3" shorter than the Brinn. So depending on which Falcon transmission tail shaft configuration you are using i would go with what CCHIEF described.
                        • Lizardracing
                          • Sep 2009
                          • 839
                          Original Brinn is 21.5" long
                          Brinn Pro 2 is 21.39"
                          Original Bert and G2 is 19"
                          (has option for 2 5/8 longer tail)
                          GM Saginaw and Muncie 23"
                          Falcon LM Trans
                          Standard lenght 22 1/8"
                          Short tail option 14"
                          Roller Slide 19.38"-24.88"
