Water Pressure switch
  • Burke1118
    • Mar 2018
    • 222
    One of my buddies melted down an engine because his radiator got punctured and he ended up losing most of the water. The problem is, water temp looked normal because it was normal before there was no water left.. I want to put a water pressure switch in so that I have an idiot light turn on if I lose all the water. What is the best way of doing this? I was thinking buy a 4 PSI pressure switch (https://www.quickcar.com/4-psi-fuel-...switch-61-730/) , weld npt bung in radiator or thermostat housing, then wire the switch to the idiot light on the Water temp on the gauge cluster. Would this work?
  • Punisher88
    • Nov 2014
    • 495
    Why not put a water pressure gauge in the car?
    • Burke1118
      • Mar 2018
      • 222
      A: no room for more gauges B: does it really matter what the pressure is? as long as its not 0. lol
        • 2020
        An idiot pressure light is very very common almost everyone I know runs one. The way your doing it is fine, I like a little more pressure then 4# but that should work
        • Burke1118
          • Mar 2018
          • 222
          Thanks BBC
          • Jking24
            • Oct 2017
            • 1514
            we use the oil temp dummy light. And it doesn't matter where you put it in the system it will work no need to weld anything special in the radiator. Top of the water pump or the intake works just fine. If you run water lines to the back of the intake most thermostat housing spacer plates have a spot right in the center that works well
            • Punisher88
              • Nov 2014
              • 495
              Is there some sort of bypass for a pressure switch upon first startup when the pressure is low that will allow the car to start? Or does the water pressure build that quickly to 4lbs? That's the reason I asked about the gauge was because i was unsure how long it would take to actually crank the car if the pressure build was slow.
                • 2020
                It doesn't hook to the ignition or anything, just a light on the dash. Light is on when no pressure, so it will be on until the cooling system builds to 4# then goes off. If it comes on when racing, you know you have a leak and the water is running out or gone at that point.
                • Punisher88
                  • Nov 2014
                  • 495
                  Gotcha. I have a low oil pressure switch on my car that will shut it down below like 15. With a bypass button I can mash to make it start initially. When the word switch was used I assumed it meant it would switch the power off below a certain pressure. Not just a warning light.
                  • CCHIEF
                    • Jul 2014
                    • 399
                    Can't say I know of anyone that doesn't have at least a light.
                    • racinrocket1
                      • 257
                      I use a adjustable fuel pressure switch for my water pressure sensor and it works fine. I have mine in my goose neck housing and I have a big idiot light so it can be seen a mile away lol. Been running this set up for about 12 yrs with no problem I just replace the switch every year so I know it's good. You also want to start your motor and let it get up to temp then set the switch at operating temperature.
                      • 96racing
                        • Nov 2010
                        • 112
                        Longacre sells this setup in a kit for like $25
                        • Jim11h
                          • 1501
                          After reading this and not knowing these could be bought I purchased kit. Wired to ignition toggle switch and other wired to sensor. Let car warm to over 110 degrees and light still on. Obviously no leaks. How long does it take to build pressure? Let run for 10mins approx.
                          • popkorn42
                            • May 2008
                            • 67
                            old chevy oil pressure sending unit works great
                            • Jking24
                              • Oct 2017
                              • 1514
                              It varies but you were probably real close to having the light out mine is out before 140 but it can vary with how much room you leave in the radiator for expansion
