Stacked spring setup
  • Higgy9991
    • May 2015
    • 66
    How much shock travel (rf) can you get before something hits the ground?
    I can get 4” before it’s getting into the ground. Looking to hit desired load at about 3 1/2 to 3/4 travel on the rf
    • CCHIEF
      • Jul 2014
      • 399
      You need to have more travel available than your target load / dynamic ride height. this may require a short body shock, or mount manipulation. Mount the nose to allow for available travel. You will need shocks valved to complement that type of deal. Keep it simple, may benefit from a more 'old school" type deal to try also. Front end bump may need a good looking at if Rack placement has changed.
        • 14324
        I look at it as the load when the chassis hits the ground better be a number you cant generate on the track under normal circumstances.
        • cross flag
          • Feb 2021
          • 7
          if using a stack on the lr what length of springs would be used
            • 14324
            Typically it's a good idea for bottom spring to be 10", to not catch on the shock body. Can get away with shorter with a divider sleeve and constant compression on the spring stack, even at full shock extension. Top can then be 8" or so. Could be less. Depends what rate it is and what you want to do with it.
