Stacking left rear springs help!!
  • Bartman28m
    • Aug 2020
    • 1
    I have never ran a stacked set up. I put a 175 spring in bottom and a 100lb spring in top.. My ride height is a inch to high on left rear and spring stack is not touching the lock nut in the middle...so do I need a lighter spring top or bottom?
    • 2019
    Sorry but don't take this the wrong way as it sounds like you're a novice or inexperienced with a stack so a couple of questions as there are 2 basic ways of doing a stack with a stop nut.
    1. Are you trying to do a progressive or digressive stack? The stop nut goes on top of floater plate with a progressive and under it for a digressive, which way are you or which way are you trying to do?
    That has to be answered first to give you any advice or directions
    • Rajflyboy
      • Feb 2020
      • 5907
      This is for off-road but appears to be a pretty good explanation of digressive shocks vs progressive and linear. https://accutuneoffroad.com/articles...shock-valving/
        Am i missing something?
        Doesnt he just have the wrong length springs?
          • 14303
          If he wants a digressive stack, maybe he just needs to preload it.
            Yeah, with that rate he's super soft. He should need a ton of preload!
              Thats only a 63.6 lb rate. Somethings off!
                • 14303
                I've run softer. They may just be too long.
