I have never ran a stacked set up. I put a 175 spring in bottom and a 100lb spring in top.. My ride height is a inch to high on left rear and spring stack is not touching the lock nut in the middle...so do I need a lighter spring top or bottom?
Stacking left rear springs help!!
Sorry but don't take this the wrong way as it sounds like you're a novice or inexperienced with a stack so a couple of questions as there are 2 basic ways of doing a stack with a stop nut.Originally posted by Bartman28m View PostI have never ran a stacked set up. I put a 175 spring in bottom and a 100lb spring in top.. My ride height is a inch to high on left rear and spring stack is not touching the lock nut in the middle...so do I need a lighter spring top or bottom?
1. Are you trying to do a progressive or digressive stack? The stop nut goes on top of floater plate with a progressive and under it for a digressive, which way are you or which way are you trying to do?
That has to be answered first to give you any advice or directions
This is for off-road but appears to be a pretty good explanation of digressive shocks vs progressive and linear. https://accutuneoffroad.com/articles...shock-valving/
I've run softer. They may just be too long.Last edited by MasterSbilt_Racer; 08-04-2020, 09:05 PM.Modern Day Spec Wedge Racing
