Spring table
  • hunterracing
    • Jan 2009
    • 303
    Spring table
    Not much said but you hear didn’t views on it. On the rear of dirt late model
    It’s the spring table is from ground to top shock bolt. But does it matter when car is in the air if rr is higher then ls static
    • 14304
    It matters once you load the spring. Both lr and rr can be noticeable change.
    • hunterracing
      • Jan 2009
      • 303
      So it matters at ride height too
        • 14304
        I'm looking at it as a point on the chassis. It doesn't matter if you are above, below, or at ride height. It has a dynamic affect on the car.
        • Kromulous
          • 3008
          How so MBR? leverage point / arm from the CG applying weight to said point?
          Just say no...
            Mr. Bolles had designed software using that info!
              • 14304
              Yes, it's about center of gravity with respect to where the weight is applied. You can help an old 90s Rayburn immensely if you drop the rr coilover mount.
                The old roll angle theorem, perhaps.
