Lr lower bar stopping against cage
  • erm95
    • Aug 2021
    • 5
    Any info on the drive this is supposed to create on a modern 4 link?
    They sell bent bars to avoid that. You don't want it to happen.
    • JustAddDirt
      • 1893
      Are you referring to the term “Running in the J”?
        I'll take my previous comments a step further.
        1) Thrust only helps you when you are both accelerating and your suspension is still drooping.
        2) This is because once the LR stops dropping with respect to the chassis, all forces between the axle and chassis must sum up to zero. The lift of the limit device equals the compression in your bars. If it didn't, something would be moving. The only gain beyond static loading, at this point, is the weight lifted to attain the higher chassis height. This is ignoring any aero changes.
        3) whatever your limiter is, if it's 100% solid, you only have your tire to absorb the shocks from tire slip and bumps in the surface.
