Additionally, any load carried by the j bar is load that cannot be carried by the 5th coil, 4 links, LR spring, or RR spring, because the j bar has taken it. Load on the rr spring would do a whole lot more to "stick the rr".
Is J-Bar still adjusted to affect rear tire loading?
Doesn't seem like modern setups use RR spring very much at all. Next to no support there. Just let it lay ona bump stop. IMO the J-bar is doing more to support RR than the spring. Does anyone still make a springbar J-Bar that has some cushion? I was around this stuff back in the day when nearly every bar that was in compression was a spring bar. Consistency was the issue. ridiculous amount of maintenance required.Originally posted by MasterSbilt_Racer View PostAdditionally, any load carried by the j bar is load that cannot be carried by the 5th coil, 4 links, LR spring, or RR spring, because the j bar has taken it. Load on the rr spring would do a whole lot more to "stick the rr".
Your mentioning the 5th coil made my brain wonder...wouldn't J-bar, which is right side of pinion mounted, tend to counter the torque arm movement to some degree? I realize leverage is a thing. Load cells everywhere. We need load cells and MORE COMPUTERS!
When I say rr spring, I mean everything on the coilover that takes load. The cars are not traveling much on the rr. Be it metallic or rubber or plastic, it's supporting weight.Originally posted by KTMLew View PostDoesn't seem like modern setups use RR spring very much at all. Next to no support there. Just let it lay ona bump stop. IMO the J-bar is doing more to support RR than the spring. Does anyone still make a springbar J-Bar that has some cushion? I was around this stuff back in the day when nearly every bar that was in compression was a spring bar. Consistency was the issue. ridiculous amount of maintenance required.
Your mentioning the 5th coil made my brain wonder...wouldn't J-bar, which is right side of pinion mounted, tend to counter the torque arm movement to some degree? I realize leverage is a thing. Load cells everywhere. We need load cells and MORE COMPUTERS!Modern Day Spec Wedge Racing
They have become large go-karts. Tire is the suspension. So...back to loading...Originally posted by MasterSbilt_Racer View PostWhen I say rr spring, I mean everything on the coilover that takes load. The cars are not traveling much on the rr. Be it metallic or rubber or plastic, it's supporting weight.
I see something that keeps getting overlooked by guys trying to get more height on the LR. When running a beam axle, you will need to also increase the roll angle or you will start pulling load off the right rear when increasing the height of the Lr.Check out my book on Amazon.
My YouTube Channel
I was honestly just being a bit dense/sarcastic.Originally posted by Jim11h View PostOk masters, that comment has my attention, what are you beating around the bush about?
The droop rule and how high your deck gets comes down to 2 thoughts.
1) how's it hanging?
2) how do you increase LR displacement with similar roll angle?Modern Day Spec Wedge Racing
