Is J-Bar still adjusted to affect rear tire loading?
    • 14324
    Additionally, any load carried by the j bar is load that cannot be carried by the 5th coil, 4 links, LR spring, or RR spring, because the j bar has taken it. Load on the rr spring would do a whole lot more to "stick the rr".
    • KTMLew
      • 1168
      Doesn't seem like modern setups use RR spring very much at all. Next to no support there. Just let it lay ona bump stop. IMO the J-bar is doing more to support RR than the spring. Does anyone still make a springbar J-Bar that has some cushion? I was around this stuff back in the day when nearly every bar that was in compression was a spring bar. Consistency was the issue. ridiculous amount of maintenance required.
      Your mentioning the 5th coil made my brain wonder...wouldn't J-bar, which is right side of pinion mounted, tend to counter the torque arm movement to some degree? I realize leverage is a thing. Load cells everywhere. We need load cells and MORE COMPUTERS!
        • 14324
        When I say rr spring, I mean everything on the coilover that takes load. The cars are not traveling much on the rr. Be it metallic or rubber or plastic, it's supporting weight.
        • KTMLew
          • 1168
          They have become large go-karts. Tire is the suspension. So...back to loading...
            • 14324
            Thats true to some extent. It's entirely true if you are an average to bad car.
            • Ltemodel
              • 307
              I see something that keeps getting overlooked by guys trying to get more height on the LR. When running a beam axle, you will need to also increase the roll angle or you will start pulling load off the right rear when increasing the height of the Lr.
              Check out my book on Amazon.
              My YouTube Channel
              • Kromulous
                • 3008
                Secret to more LR Hike, is compressing the RR, and keeping it compressed.
                Just say no...
                  • 14324
                  I thought it was just a longer chain.
                  • Kromulous
                    • 3008
                    Well, that too.
                    But the Chain, a tight Chain, is just a pivot point, from right to left.
                    In my humble opinion, and often wrong... LOL
                    Just say no...
                    • Jim11h
                      • 1501
                      Ok masters, that comment has my attention, what are you beating around the bush about?
                        • 14324
                        I was honestly just being a bit dense/sarcastic.
                        The droop rule and how high your deck gets comes down to 2 thoughts.
                        1) how's it hanging?
                        2) how do you increase LR displacement with similar roll angle?
