1" longer ball joints
  • Cranky
    • Sep 2014
    • 174
    What is the point of 1/2" or 1" longer ball joints top and bottom? Are they just used for extended travel of the RF suspension?
  • grt74
    • Jul 2009
    • 1380
    camber curve, and control arm angles, keeping the car out of the ground
    longer is weaker though, its a trade off, use as short as you can as a rule
    • manwplan
      • 351
      there's zero magic to a longer ball joint. changing your spindle height will accomplish the same thing.
      • KTMLew
        • 1168
        Correct. Ball jernts are just cheaper.
        • LRtireCHANGER
          • Mar 2017
          • 73
          If you go to a longer top, or a longer bottom, or both, ball joint..........you are effectively changing the height of the top a-arm. Let that thought set in for a minute. You are keeping the bottiom a-arm in the same possition, but you are raising the top a-arm. By doing this, you are changing the rate of rf tire lean.
          • grt74
            • Jul 2009
            • 1380
            longer lower balljoint also lowers the chassis to the ground if you don't change the spindle, have to pay attention to that one
            • Ltemodel
              • 307
              Having different stems is a good way of testing different heights without building new spindles. Once you hit on something, I would always build a new spindle with that height adjusted. Running stock ball joints just makes things easier. If you ever had to borrow parts from someone, it would just make things easier.
              Check out my book on Amazon.
              My YouTube Channel
