any ideas?!
  • jwracer11
    • 95
    any ideas?!
    How do you fix a 4 wheel slide in the center of the corner? The car gets in good, but when it rolls over, I have to wait for it to stop sliding, when it finally hooks up, it comes off the corner good, but bogged down a bit. This happens when the track has plenty of bite in it. I don't have any excess j-bar. I am almost by the book on set up. It 's a 2010 Rocket. Any ideas? Thanks in advance!
    Joe Warren
    http://www.jwmotorsports11.com
  • Racer63
    • 285
    Lazer. J/K........
    • jedclampit
      • 613
      Where is your ballast mounted?
      • Graff Spee
        • 881
        Yeah, you may want to raise it. How about left side? May need to lower percentage and or raise ballast placement. Have you messed with rear roll center? Are all joints lubed well? This could just be a binding issue. Tire pressure too low on rr for heavy track? (runnin on sidewall) If no spotter, look at mud staines on sidewall.
        • oldblue
          • Mar 2010
          • 39
          I think Graff Spree has got you covered! you got something in a bind or wgt is to low.an when ckin dont for get to ck droop on lft rear
          • jwracer11
            • 95
            I was thinking something was in a bind, too... but I lube my heims every week, and went thru the rear and couldn't find anything... funny, the car was super fast until about two weeks ago.. that's why I was thinking something was bound up. The drop is set at 12 3/4... and I have the ballast set evenly... 45 lbs high along the tail end of the driveshaft, 45 lbs low along the tail end of the driveshaft, 25 lbs beside the seat (right side of the seat in the pit), and 25 lbs low near the RR lower mount. Maybe I will raise that 25 lbs off the RR...Tire pressure is around 12lbs.... Thanks, guys...
            Hey Imler, I might just pull that old Lazer out if I have, too... that thing won a bunch of races, too!! LoL
            Joe Warren
            • crate late
              • Jun 2009
              • 137
              Originally posted by jwracer11 View Post
              ...Tire pressure is around 12lbs.... LoL
              12 lbs on the RR. Is this normal? I usually go for around 10 or 10.5 on the RR, am I too low? What are typical tire pressures you guys are running all the way around the car? I don't mean to highjack the thread but I'm curious about this.
              • C10
                • Nov 2008
                • 359
                The rocket set up books says 10 LF, 12 RF, 10 RR, 6 LR
                • jwracer11
                  • 95
                  no, 10lbs is normal... I only run 11-12lbs for qualifying when the track has a lot of bite in it. We only get about 3 laps for timed hot laps... and then I drop back to 10lbs for the feature.
                  Joe Warren
                  • jwracer11
                    • 95
                    Originally posted by Living_Truth
                    Have you hit anything or run a real rough track around the time this started? Bent ball joints and spindles will affect roll, and can sometimes be hard to spot.
                    that's a good point, I will check them... what's the best way to check ball joints?
                    Joe Warren
                    • jedclampit
                      • 613
                      Possibilities if nothing has changed with set up..and track conditions.
                      Shock settings if d/a shocks.
                      Tires.
                      Tire pressures, your gauge may be junk, check it against a few of your buds gauges.
                      If all is good, take some left side weight out.
                      Which way are your front wheels pointed when sliding?
                      Post your setup.
                      ...............Or just slow down!
                      • Graff Spee
                        • 881
                        You may have a bent or blown shock! Pull em off dyno them and see how far off they are from the last sheets. Good luck!
                        • RacerX10
                          • 571
                          Agree on check shocks. Anytime my car went bad for no reason it was a broken shock issue of some sort.
                          • jwracer11
                            • 95
                            we have to run these cheap $79 pro shocks (local crate rules). they have about 15 races on them, and although they seem to be ok, I am going to change them and see what happens. I have 54.5% left side weight. should i be closer to 54%? rear weight is 54.3%
                            the track doesn't seem to have changed too much, but it has slown down a little bit...but we qualify right after the track is run in to start the night, so I figured that wouldn't be an issue... ball joints and spindles checked out ok...
                            I am going to see what the new shocks, raising a little ballast does and maybe try somewhere around 54.3% left side.
                            thanks for everyone's input. much appreciated!!
                            Joe Warren
                            • matt8
                              • Nov 2007
                              • 64
                              drop on lr should be at 13 to 13 1/4 or car wont get on bars properly
