what type of grinder on tires
  • ilustfordust
    • 135
    What type of grinder are the big name teams using. I know its is adjustible speed is it a grinder buffer or polisher. what size disc and what speeds plus what type of disc and disc attachment
  • grt74
    • Jul 2009
    • 1380
    We use a dewalt buffer/grinder with adjustable speed with 36 or 40 grit make sure to go around rear tires and across the fronts there is a little to that and also buff the tires dont grind the snot out of them to many times i see guys grinding so hard and smoking there tires thats just cooking them not good for the tires hope this helps
    • mudderfudder
      • Aug 2008
      • 264
      I use a Snap-On buffer varible speed buffer that i bought 10 yrs ago and that seems to work great. One thing you got to look at is the weight.... alot of prep in the tire department is key and you dont want to be muscling a heavy peice around if you can use something just as good that weighs 2 pounds less. Who knows if Snap-On makes that same buffer but i like it way better than the dewalt. I use 36 grit mostly but i am not preparing for as many tracks as others are either. Good luck and hope you get the info you need.
      • RCJ
        • Nov 2007
        • 509
        Harbor freight has a one for around $40.I like it because it is real light.I've used it for a year,went and bought a second one because you know that its going to quit at the worst time .It's still working good .
        • mudderfudder
          • Aug 2008
          • 264
          I just got done looking throu a northen tool catalog and they also have a varible speed 1200-3000 rpm sander for about the same price. Happy Thanksgiving!!!!
          • ilustfordust
            • 135
            What size wheel and what type of attachment felcro type and what speed do you run on
            • fast_crew
              • 844
              We use the HF buffer on Sprint car tires and it's lasted 2 yrs so far, will probably exchange it for a new one over winter. Look for a 20% off coupon and wait until it's on sale, I think we paid $26 for ours .
              Josh K.
              • gadirtracer
                • 1039
                Harbor Freight buffer here too... going on 2 years now...
                Gill T. Azell
                • Egoracing
                  • 4852
                  We had an HF buffer that was at least 4 years old last check (3 years ago) and I think it is still working.
                  • Rocket_racing
                    • Oct 2009
                    • 44
                    I was just checking out HF, are you guys talking about using the grinders or polishers, the grinders that I looked at are not speed adjustable, but the polishers are variable speed.
                    • fast_crew
                      • 844
                      Listed as 7" sander/buffer or polisher. IIRC. Comes with a velcro backed sanding pad, and polishing bonnets.
                      Josh K.
                      • Rocket_racing
                        • Oct 2009
                        • 44
                        thanks! Looks like HF had them on sale right now!
