After reading the stagger threads, i was curious to how someone could come up with a good way to control the rear steer in a car according to the cornering of a track. The stagger thread used wheel spin ratios and corner radius to dictate correct stagger for maximum tire patch use. How does the rear steer come into play. and we often adjust the droop to let the car jack up or hold it down, and track the bar angles at dynamic state and the rear steer movement. but really dont have any idea in a geometry way to explain what works better. For example what works better in certain situiations. More rear steer when?? Any comments on this.
How to Adjust Droop to control Rear Steer
also kinda curious on this. we typically took rear steer out as the night went on (track slicked), but didn't always improve a whole lot. of course we also made other changes as well, and I'm not sure if this was just a crutch, or an unnecessary change that caused other problems. towards the end we were trying more static and dynamic rear steer, but not having much noticeable difference.
Well first and foremost, you should use a chain (or something similar) connected to the axle tube to control your LR droop (travel). Many people rely on the shock in front for this which (no offense to anyone that does it) is just plain stupid. For one, it WILL eventually destroy your shock. And for two, the amount of travel allowed will change with static bar angle changes due to the change in indexing of the birdcage.
That being said, use a chain from the frame to the axle tube to limit your LR travel.
Generally speaking, you don't want your top LR bar to exceed 45 degrees of angle at full travel. A lot of guys will start the evening with their chain set to allow them about 38 degrees and then move toward 45 as the track slicks off through the night. Not by changing the static bar angle but by changing the length of the chain. The thinking being that more bar angle will provide a tighter overall race car. That is true (in general) but you are also allowing for more rear steer which is somewhat counteracting (making the car loose) the tightness that you gain from the increased dynamic bar angle. Net-net, the result is still probably a tighter car. BUT if you really wanted to increase your travel and not change your rear steer (as much) you could simply lower your left BOTTOM bar on the frame as you increased your travel limit. This will settle the rear steer down quite a bit and it will provide some added drive just by itself. Spend some time in the shop doing the homework with your car on jackstands with the shocks and springs off just to see what the bar changes and chain length changes are doing to rear steer and you'll have a much better appreciation for it. A jack, a marker, a tape measure, a plumb bob, a case of beer, and a few hours of time are all you need.Last edited by Matt49; 12-02-2011, 05:59 PM.
Don't forget, this used to be a large problem, not as much anymore, but many drivers like to go up on bar angle and rear steer for slick, then they think the car is extremely tight.
Really the rear end is trying to rotate around, so you turn the front on corner exit, and now all four walk for the wall, so the car drifts out toward the wall hard and some drivers count this has tight, it's a fake tight, be sure your not falling in this trap. Older 2002-2006 mods with extremely short bars show this to an extreme, the driver thinks its tight, and is on the gas but not going forward hard.
That is exactly what i did. We went to the races real early one day and i spent the whole time tracking every movement from bar angle to rear steer and chain length. and wrote down how it all effected each other.
chain
well matt, many shows have been won with no chain! maybe you just didnt know how to keep it from tearing itself up..stupid in latemodel racing, is not keeping an open mind..i think your in violation..
The chain takes nothing away from the setup, so why would anyone not want to be safe instead of sorry?Originally posted by huntingrip View Postwell matt, many shows have been won with no chain! maybe you just didnt know how to keep it from tearing itself up..stupid in latemodel racing, is not keeping an open mind..i think your in violation..Modern Day Spec Wedge Racing
Yup...and races have also been won on flat tires, bent spindles, broken axle tubes, motors with no oil pressure, etc. But it doesn't make any of them practical or the right way to do things now does it?Originally posted by huntingrip View Postwell matt, many shows have been won with no chain! maybe you just didnt know how to keep it from tearing itself up..stupid in latemodel racing, is not keeping an open mind..i think your in violation..
In my post, did I not say "no offense to anyone"??? I was simply trying to make a point which you clearly didn't get. I am in fact very open minded. So much so that I would like you to enlighten me on the proper way to use the shock as a travel limiter without abusing it. Also please explain to all of us how you are keeping the max travel the same (when using said shock as a travel limiter) when a bar changed is made which makes the birdcage index differently. I'm REALLY interested in hearing that.
If you can't provide good explanations for both, I'm going to keep using a chain if that's okay with you - closed minded as that may be.
And I promise not to make any comment about any idea being stupid ever again.
I guess even comments on 4m.net have to be politically correct these days.
Matt, That was a good explanation of chain use beyond a limiter. Don't let em troll ya
I still haven't seen a real solid answer, though, on if you need to change rear steer based on conditions, try to control it when changing bar angles/chain length, or if it's something you settle in on based track size and line and try to keep the same.
It seemed in the stagger discussions, that most seemed to agree that there was an ideal stagger to use all night for your track, based on corner diameter/banking. So i'm curious if, as with stagger, there's an ideal amount of rear steer to try and hit for a track, and any changes made should be to try and effect bite while keeping rear/roll steer close to the same.
So, why do the Rockets generally have the spacer that mounts on the underslung which controls the droop instead of the chain. Ive heard a few different reasons, but we use the chain setup while most Rockets use the spacer that can rotate and change the gap where the rear end hits the underslung. Why??
Not exactly...Originally posted by fastford View Postwhen a car is on the chain, you may as well take the coilover off on the left rear cause its doing nothing.
Taking the chain off won't put the car back down on the spring. You'd be off the spring with or without the chain (hence the term "on the bars").
The spring is critical in getting it to transition up on the bars through the corner. Just because the spring ends up unseated doesn't mean it didn't play a role in getting it that way.
The LR spring is playing a key roll and how much weight gets unloaded from the LR to the RR and how easily the car can hike up with throttle application which generates the bar angle (thrust angle) that you need to get LR drive. A softer LR spring promotes this which is why a softer LR spring (behind the birdcage that is) will typically make the car tighter from center off.
So the chain is only limiting the potential bar angle and potential rear steer. It isn't really doing anything to the affects the LR spring has on the setup in of itself.
At that point it is doing nothing. The spring is also doing nothing when your shock is fully extended and the spring is unloaded.Originally posted by fastford View Postwhen a car is on the chain, you may as well take the coilover off on the left rear cause its doing nothing.Modern Day Spec Wedge Racing
As far as rear steer for track conditions...Originally posted by dualdj1 View PostMatt, That was a good explanation of chain use beyond a limiter. Don't let em troll ya
Consider this, the most common issue people have on heavy/tacky race tracks is getting the car to turn on entry. That being said, I know of some people (can't say I'm one of them at the moment) that increase their compression and gas pressure on their LR shocks so that the car maintains more rear steer on entry (doesn't fall off the bars as hard) and turns easier. Just food for thought.
On the other hand, I can tell you that we have increased chain length as the track slicks in an effort to increase upper bar angle potential. While it does also increase rear steer we find the net result to be tighter corner exit.
There are also some that are of the school of though that more rear steer can actually help you roll through the center of the corner on a slick track without having to get the car sideways.
A lot of stuff to think about.
I like workin with a limiter chain on RR so as you can't extend that RR side shock, or drop over an inch and a half longer than ride height at very most can control rearend movement and seems to help drive off. JMHO. As for being PC, ain't happening.Originally posted by Matt49 View PostAs far as rear steer for track conditions...
