we have changed to a steel head and run
LF 500
RF STANDARD DOUBLE STACK
RR 225
LR DOUBLE STACK
J-BAR 1in below pinion 8 1/2 rake
08 barry wright copy with extra bar and shock hole but every thing is the same short of the more adjustments.
it is to free and rotates to fast in the middel which end up spinning tires from the middel off. the dryer it get the worse it gets. wet or tacky it is bad fast but once it slicks off it is junk.tried ajusting double stack and bar angels but same results. talked to afco this morning they said to get rid of the double stack. but they are the ones that steered us in the direction.
can any one give some better advice on if it is the double stack or maybe something that i am over looking. thanks
LF 500
RR 225
LR DOUBLE STACK
