I know the slider does work better with the longer 700lb on the bottom and the shorter 400lb on the top, thats what AFCO seems to sell everyone, BUT that set up only works only on the stickyer tracks, not the slick and causes a push from the apex out as the 700 takes over too soon for the slick. Those springs are on my car right now so I can't measure them exactly but I think it is like a 4" or 5" 400lb and an 8" 700lb from AFCO. I have gotten the AFCO to slide and work well with the shorter 400lb on the bottom in th past, but it is right at the bottom of the shock body and you need to make sure the longer side of the nylon slider is pointed up.
The last 2 years on slick I use a Hypercoil 7" 400lb on the bottom and a Hypercoil 6" 700lb on the top as it lets the slider have more contact with the shock body than the AFCO set up. Always watch those dang lock rings as they can and do move.
